    Hello, any help is appreciated.
    I'm trying to extract chapters from a DVD into MPEG format to be later burned to a DVD-R
    Can DVD decrypter do this? when I select chapters it puts the files on my hard drive as IFO and VOB files, I'm not familiar how to use these, it would be easier just to have the chapter as a single MPEG file.
    Thanks so much.
  2. VH Veteran jimmalenko's Avatar
    Set File Splitting to "By Chapter" in Tools > Settings > IFO Mode and then use IFO Mode to rip. You should be able to tick just the chapters you require. Each chapter will be its own VOB file, which you can then extract to MPEG using VOB2MPG.
    If in doubt, Google it.
