I have an Insignia NS-8PDVDA portable DVD player. Currently, I can play DVDs and Audio CDs using this player but am not able to play VCDs in it.
Could anyone please let me know if there is any way that I can use this player to play VCDs?
Homemade VCDs on CDR or CDRW? Have you made them? if so how and what tools?
If it won't support VCD, it's a small task reauthoring your VCDs to DVD - you'll be able to fit 6-7 VCD on one DVD5.
Rip mpg out of VCD with VCDGear. Author mpg as DVD with TMPGEnc DVD Author.
/Mats
The VCDs that I had tried are not made by me, I tried using branded VCDs. Is there any ways to add VCD playing option if this utility is not available in the player?
Unfortunately, portable players are notorious for having problems with VCD. It's a firmware issue, so you'll have to look for hacked firmware (which probably doesn't exist, but you need to look for this since it's your player) and then be brave enough to replace your firmware with the hacked one and hope it works. Most likely there is nothing you can do. You need to check this stuff PRIOR to buying. Caveat emptor.
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 8Last Post: 19th Apr 2012, 15:30 -
need region code for Insignia NS dvd 1-A player
By gegely in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Mar 2009, 17:05 -
Hack Insignia NS-MVDS7 portable DVD player
By vorls in forum DVD & Blu-ray PlayersReplies: 9Last Post: 12th Nov 2008, 19:07 -
Insignia DVD player NS-DVD1-A
By tournicotii in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th Apr 2008, 20:20 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 19:28
