VideoHelp.com Forum
    Does anyone know how to adjust the audio/video sync of H.264 encoded mp4 files? Do i need to remux them? If so how do i do it without reencoding everything again (many files...)?
    I can adjust playback using various players like QTSync on the mac but I'm pretty keen to fix the source files so i can archive them and have them work any old time (little obsession with archiving, I think I was probably a librarian in a past life...).
    I use a mac primarily but have a windows box also.
    Thanks in advance!
    You can demux and remux with mp4box or use the windows gui YAMB.
    QTSync saves a reference movie, and you can open that in Quicktime Pro (if you have it) and export to mp4 with both video and audio set to "passthrough".
    Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
  1. Converted video (mp4): audio out of sync
    By darknezx in forum Video Conversion
    Last Post: 22nd Mar 2011, 02:25
  2. Audio/video out of sync after converting (avi to mp4)
    By Foxy Gogo in forum Video Conversion
    Last Post: 10th May 2010, 12:13
  3. Replies: 0
    Last Post: 6th Apr 2010, 18:03
  4. Replies: 0
    Last Post: 4th Mar 2009, 06:42
  5. Audio out of sync with video: FLV > MP4 using ffdshow
    By jk318 in forum Video Conversion
    Last Post: 16th Aug 2007, 21:07
