I recovered my photos from an old hard disk but i can not view many of the jpgs i had
i use acdsee 5.0 and it says Bicubic Interpolation and file is blank grey page
What is that ? can i repair these files
Thank you
Thread: Can not view Jpgs !!!
If by "recovered" you mean the drive failed and you used data recovery software to recover the files, then the files are corrupt and you won't be able to "repair" them.
Google is your Friend
Of course, you could always use your last backup of the hard drive before the "recovery" to restore your most precious pics.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
it is a hard question,i don't if there are any software can do this.
but i kown that if the picture is very important, you can repair it manually with some Binary-Edit Programe.
you need to learn something about how the format of jpg is defined.
as far as i kown ,it is not a easy thing to do
Sony Vegas Red JPGs on Timeline ?
By blewyn in forum EditingReplies: 4Last Post: 5th Feb 2012, 19:23 -
minizing artifacts with MEncoder for time lapse from JPGs
By jon_bondy in forum Video ConversionReplies: 0Last Post: 4th Mar 2011, 14:52 -
SVCD with jpgs and wav
By gkma01 in forum Authoring (VCD/SVCD)Replies: 10Last Post: 28th Aug 2008, 08:03 -
Phillips 5982 won't display jpgs
By wannabeswede in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Jan 2008, 07:26 -
Is there a maximum resolution or size for jpgs imported into Vegas 7?
By nzo in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 20:18
Statistics
Newest guides
Latest tool updates
New media comments
