I am capturing full ota hdtv transport streams which I can convert to standard dvd. But I need a way to convert to full resolution xvid in mpeg 4 wrapper.
Currently after capture I use mpeg2repair on the transport streams as they always have errors then use hdtvtompeg2 to convert to dvd compliment mpeg2 then use ulead 9 se to make dvd. If files are to large I use dvd re builder pro to fit to standard single side dvd.
Due to space limitations I need to convert to a format like xvid for full hdtv resolution of material which justifies being in hi definition. I can use the dvi out and spdif out to my home theater system for playback.
So how can I go from a hd transport stream to a hd mpeg4 wraped xvid hopefully using oss free software.
http://www.videohelp.com/guides.php?...elect=4;13#912
mpeg4 wrapper? do you mean a mp4? then you can use yamb to make a mp4 from the xvid avi.
Thank you, I see your pointer directs me to a "how to" so I will try to see if I can figure it out.Originally Posted by Baldrick
Correct me if I am wrong. The avi is the video file and mp4 is the wrapper. However, how do I get xvid to recognize the transport file which has an exponent of .tp. The article talks of .ts files. I am not lazy. I have done considerable research but I am buried in info and confused. Sort of like if you walked onto an inpatient psychiatric unit, were handed a dsm 4 to read and told to start diagnosing and treating patients.
Hi-
DGIndex opens transport streams. Make a D2V project file and an AviSynth script file (an .avs) for frameserving into VDubMod. Then set up for XviD encoding. This is all explained in detail in the docs included with the DGMPGDec package, particularly the QuickStart Guide:
http://neuron2.net/dgmpgdec/QuickStart.html
The Doom9 Capture Guide also has a ton of useful information:
http://www.doom9.org/capture/start.html
No offense, but that guide to which Baldrick pointed, while useful for teaching the basics I suppose, is using old and obsolete apps.
Combine two transport streams.
By Deadeditor in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2011, 08:12 -
Seeking in Transport Streams(.TS)
By deepp in forum ProgrammingReplies: 0Last Post: 15th Jul 2010, 16:00 -
Anyone please tell me how to convert xvid to mpeg4-part2(mp4v2)?
By xjohn in forum Video ConversionReplies: 11Last Post: 18th Mar 2010, 09:02 -
Joining transport streams ?
By NotSoEasy in forum DVB / HDTVReplies: 7Last Post: 3rd Jul 2009, 18:32 -
European transport streams
By branch in forum DVB / HDTVReplies: 26Last Post: 27th Mar 2008, 03:50
Statistics
Newest guides
Latest tool updates
New media comments
