VideoHelp.com Forum
    i have some movies that will play only with VLC media player but i want to encode them to vcd so i can burn them to disc i have used TMPGEnc but they still turn out messy what programe can i use
    VLC is a great player because it brings it's own codecs with it for decoding video. This means it can play most videos, even if you don't have the right codecs installed on your system. However, other programs cannot use VLC codecs, and so require that you have the right codecs in place.
    Open the files you are trying to convert using avicodec or g-spot 2.6x and look at what codecs they require. Install just those codecs (no codec packs - shortcuts lead to misery), then try again. If they play, but badly, it may just be time to update some of the codecs you already have. If you have already installed codec packs in the past, you may have found the cause of your problems.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    turn out messy? how? please explain.
  1. Replies: 6
    Last Post: 20th Mar 2012, 10:22
  2. display size between windows media player and VLC player
    By kool_k in forum Software Playing
    Last Post: 6th Aug 2011, 15:18
  3. Better media player than VLC?
    By meneedit in forum Software Playing
    Last Post: 16th Nov 2010, 07:32
  4. vlc media player
    By natty in forum Newbie / General discussions
    Last Post: 30th Aug 2010, 13:10
  5. VLC Media Player
    By Flying Doctor in forum Video Conversion
    Last Post: 26th Jun 2007, 09:38
