Hi,
I have a Pioneer DVD recorder where I recorded a VR disc (On a DVD-RW).
I made some edits using the recorder and "Finalized" the disc.
Given that when you edit a VR disc, it does not actally "remove" the content, it just tells the DVD player to "Skip" certian parts of the disc.. right?
For some reason, the Pioneer unit will NOT unfinalize the disc.
Is there a computer program that will "Unfinalize" the disc.. or better yet just "Extract" the original VR recording so I can burn the program without the edits?
I tried Isobuser.. and no luck.
Do please let me know if there is anything out there that can do this.
Thanks,
Peter
http://forum.videohelp.com/viewtopic.php?t=314820
... this may help you
Originally Posted by Kaapo
You can't unfinalize. But you could most likely copy the disc to another and NOT finalize the copy.
Google is your Friend
I've never had this problem however you could try this process.
The VOBs themselves should be complete and unedited. My guess is that when you edit you are just changing the navigation structure of the disc.
So it should be as simple as copy the .vobs to your hard drive and extract the mpgs from them or just reauthor them.
I know that VideoReDo can take a vob and save a mpg because I've used it for that as well as very accurate edits. There is a trial version @ http://www.videoredo.com/Download.htm that will work, keep in mind that you need to register it as a trial to get the trial key to enable it or else it will truncate the saved files.
Then take the mpgs and reauthor them
Confusion: Magnavox DVD/VCR recorder disc/mode
By dobe in forum DVD & Blu-ray RecordersReplies: 5Last Post: 7th Mar 2011, 01:27 -
Can you unfinalize a DVD-R?
By imrealdumb in forum EditingReplies: 8Last Post: 28th Oct 2009, 22:55 -
By imrealdumb in forum Authoring (DVD)Replies: 1Last Post: 24th Oct 2009, 13:11 -
Does BD-Rebuilder Full Disc mode work?
By ronorkis in forum Blu-ray RippingReplies: 22Last Post: 1st Sep 2009, 05:12 -
restore unfinalize DVD from camcorder
By sangleweb in forum RestorationReplies: 3Last Post: 10th Jun 2007, 10:04
Statistics
Newest guides
Latest tool updates
New media comments
