Hi Major... and everyone out there...
I installed ffmpegx & reallibs as per the How-Tos (exactly like the how tos) but my ffmpegx freezes everytime i try to open a real media file... everything else is fine...
Can someone help? i'm using a macbook...
Thread: ffmpeg freezes
Check the filename extension. Make it ".rm"/".rmvb" for genuine video files, not ".ram", as that is reserved for link files, which should be small text files with a URL in it.
This can get mixed up easily, as often you get a ".ram" file when you try to download a Real video file, even when the file on the server is a ".rm" file.
Giving it the right extension back may help recognize the source file better.
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum CapturingReplies: 1Last Post: 14th Feb 2012, 04:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 05:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 22:44 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
Statistics
Newest guides
Latest tool updates
New media comments
