VideoHelp.com Forum
  1. Member qknet's Avatar
    As far as I observe Idx/sub can contain several languages.
    The idx/sub makers (say, txt2vobsub) can create only one-language idx/sub. Are there any ways to merge two pairs of idx/sub into a single pair?
    I don't think such a software exists. See http://forum.doom9.org/showthread.ph...625#post871625 but zion hasn't made his tool available.
  3. Member qknet's Avatar
    hope he can make it soon.
    Sometimes it is just hard to mux divx container when vbr MP3 is used. In such a case, i choose to leave the avi file as is and use idx/sub for subtitle for playing on my SAP. Again, sometimes I want two subtitle tracks.....
  4. Member manusse's Avatar
    Hi,
    Next version of SubtitleCreator (2.1) that should be out in december will support VobSub format and allow to add a stream to an existing VobSub file, thus solving this problem.
    Cheers
    Manusse
  5. Member manusse's Avatar
    You can try SubtitleCreator 2.1 beta 4 that should do the job. As it is a beta, please test it and give your feedback.
    Cheers
    manusse
  1. Replies: 3
    Last Post: 16th Feb 2012, 19:37
  2. subs look transparent (sub/idx)
    By X_Splinter in forum Subtitle
    Last Post: 22nd Dec 2010, 10:26
  3. .SRT (text) to .SUB/.IDX (image) subs
    By Sheavi in forum Subtitle
    Last Post: 29th Dec 2009, 03:42
  4. Converting sub and idx subs into srt
    By peyem in forum Subtitle
    Last Post: 4th Apr 2008, 18:23
  5. Replies: 5
    Last Post: 29th Mar 2008, 08:58
