VideoHelp.com Forum
    Virtualdub has a "direct stream" processing feature feature that lets you exctract clips out of avi video retaining all the video/audio properties. How do I do the same with mpeg, i.e. I want to exctract a clip out of an mpeg file but want to keep the resolution, bitrate etc. (keep it DVD compliant).
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You can't. VD only outputs different 'flavors' of AVI, not MPEG. If you wanted a low compression codec for output, you could use HuffUV or even DV. (Install the Panasonic DV codec or similar.)
    Then you could re-encode it to MPEG-2, DVD compliant video with a MPEG encoder like TMPGEnc or similar. But you can keep the same resolution.
    For MPEGs, you might look into one of the MPEG editors listed in 'Tools' to the left. <<<<<< VideoReDo and MPEG VCR are a couple of popular choices. You can also do some editing with TMPGEnc encoder (Merge & Cut) or TMPGEnc DVD Author.
  1. Unable to find "Play next clip" when authoring DVD
    By zonag5 in forum Authoring (DVD)
    Last Post: 16th Oct 2010, 01:50
  2. Replies: 24
    Last Post: 30th Sep 2010, 03:17
  3. Replies: 30
    Last Post: 21st Oct 2009, 14:13
  4. Premiere Pro "direct stream copy"?
    By Colmino in forum Newbie / General discussions
    Last Post: 9th May 2008, 10:31
  5. Why do I have 2 files? "Movie Clip" and "M2V File"
    By tygger in forum Newbie / General discussions
    Last Post: 22nd Jun 2007, 21:55
