Ok I know how to convert and save videos without H264. But this is a different problem I just encountered. This particular video has both H264 and 0x00ff (AAC) audio.
Here's the GSpot stats:
This happens when I open the video in Virtual DUBmod and VirtualDub .. it doesnt matter which one I use.
I tried to full process compress the AAC audio and save it to either MP3 or AC3... none of worked. This is what it said:
I've done this before with other videos with different audio besides AAC and it worked fine..
I thought it would solve the problem if I installed AC3 ACM Decompressor and other codecs. But I guess AAC is different from AAC? Nothing worked for me.
So what do I do? Is there a AAC decompressor out there? Or other codecs I have to install? I can convert this video and save it without h264 just fine, but everytime I do that, THERES NO AUDIO! I also tried different audio converters, but that didnt work either.
Please he*lp....Thanks ^^
P.S. I also got this message when I open the video. I guess I reinstalled some codecs it needed to open because I didnt see this message before. I was just frustrated with this and deleted some codec packs that I thought would solve my problem...but it didnt..
Try using this http://alltoavi.sourceforge.net/
I had the same problem trying to convert an MKV that had AAC audio and this did it with no problems. This should be able to convert an AVI to AVI without the AAC and it supports H264
Thanks Im gonna try it right now.. and see if it works. Thanks!
-- EDIT - yay it worked! thanks.. but i have another question
azumi_yo - does the videos ever loose image quality while using alltoavi?
Not that I've seen no. I've used it to convert several MKVs to AVI and the quaility looks good. Your output AVI might come out larger but the quailty should be the same or close to it.Originally Posted by robodot
Have you ever encountered "Skipping frame!" on alltoavi? I dont know if thats normal... I see like a bunch of it.. and also see "Error while decoding frame"? I scan through the video and it looks fine.. -__-;; maybe I have to see it the whole thing if theres any error?Originally Posted by azumi_yo
Most players have some form of error control that can hide or compensate for errors found in the stream, if they are mild enough. It might be as simple as skipping the bad frames, or creating a blended frame to fill the gaps. Encoders, on the otherhand, look at every frame, and will have problems with damaged or corrupt frames.
@azumi_yo : have you tried using mkvextract ? Depending on the codec used, you may not need to re-encode the mkv to get an avi - it may already have Xvid or similar content. Every re-encode with a lossy codec does reduces quality to some degree, even with high bitrates.
Yes, I've seen skip frame and dublicate frame errors but I couldn't see any difference in the playback of the video. I also get that a lot with convertX depending on the video. Just review the video first before saving it to make sure it's ok for you.Originally Posted by robodot
Yeah I've used that before. The alltoavi works like an automatic form of MKVextract. Either way I always convert ogms, mkvs to avi so I can put them on DVD.Originally Posted by guns1inger
like gspot.. what do you use to know the video bitrate or other specs for .mkv and .ogm?
mux h264/aac flv into h264/aac mkv
By Pitorasilo in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2011, 09:36 -
How to make the audio louder in an H264/AAC video
By rumplestiltskin in forum MacReplies: 17Last Post: 29th Jun 2011, 21:17 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 09:05 -
h264/AAC mkv -> h264/AAC mp4?
By joshwa in forum Video ConversionReplies: 7Last Post: 4th Jan 2008, 11:08 -
youtube FLV video with h264 (x264) and/or aac (mp4) audio
By wiseant in forum Video ConversionReplies: 1Last Post: 26th Oct 2007, 16:49
