VideoHelp.com Forum
Results 1 to 9 of 9
    (This is a question to owners of the LG LRH-780 HD/DVD recorder)
    Hi,
    I am thinking of buying the LG LRH-780 HD/DVD recorder, but before doing so
    I need to find out exactly how long one can record on a Dual Layer DVD
    at the maximum quality (XP). Can one record a *full* 2 hours of video?
    I think that some DVD recorders (like the Liteon HD-760) record a few minutes less
    than two full hours (at XP on DL disks), and this is a serious drawback for me:
    I need to archive about one hundred 2hours 8mm Svideo tapes, and I don't
    want to lose few minutes at the end of each tape, or to record at a lower quality
    than XP.
    Thanks a lot for your help!
  2. It's not quite 2 hours on any DVD Recorder assuming they use the maximum allowed bitrate for XP (or HQ as it may be called on some models).
    I usually get about 115 minutes. 5 minutes less than 2 hours. Once again, this is not the "fault" of the recorder as much as it is the size of a DL disc as it compares to the maximum allowed DVD-compliant MPEG2 bitrate. The designers of the DVD Recorders do not choose this maximum allowed bitrate, it is in the DVD Specifications, they just conform to those specifications.
    EDIT: Using a ballpark total bitrate of 10Mb/s, and a disc size of 8.55GB, I get exactly 114 minutes. Authoring takes up some space too, and 10Mb/s is a bit generous, usually it's either:
    8Mb/s video plus 1.536Mb/s audio (LPCM) or
    9.2Mb/s video plus 0.384Mb/s audio (AC3)
    which comes to 9.536Mb/s for LPCM and 9.584Mb/s for AC3.
    Rounding that to 9.6Mb/s, and dividing that into the 8.55GB disc size yields 118.75 minutes. And again, some of that space will be needed for authoring information. Also, there is a small amount of overhead in both the VOB files themselves, and the file structure that contains them, but it is just a tiny fraction of a percent of the total capacity of the disc.
    Thanks a lot for your detailed and informative reply.
    This means that to backup 120-minutes Hi-8 video tapes
    at the highest possible quality on DL disks, I need to
    find a DVD recorder that is capable of "best fit"
    (flexible) recording.
    I think the LG LRH-780 that I was considering does not provide
    such a recording mode, so I will have to look for another HD/DVD recorder...
  4. I use a Pioneer 633 for such things, the newer model (640) can easily do it.
    One step down in recording quality (MN31) should be plenty to allow the extra 5-10 minutes to fit.
    Be sure to record at that quality first to the HDD, then High-Speed dub to DL DVD, to avoid the "Title-Split" problem that happens with Real-Time dubs.
    Hi,
    Thanks for your Pioneer recommendation
    and the tip to first dub the tape on the HD.
    Unfortunately the Pioneer 640 (the currently available model)
    does not have a DV input, something that I found very convenient
    to have on my Liteon 5005: it is nice to use just a single cable
    to transfer from a DV camcorder...
    But I guess I will have to compromise somewhere!
  6. Oh right. Yes that is unfortunate. I got used to having it on my 633, forgot the dropped it for the 640.
    Yes, that's what they call progress
    Hi,
    i m locking for the free zone code for my LG LRH-780 HD/DVD recorder I need to find out exactly how i can make it free zone, because i have many dvd from France..
    thanks a lot
    i know this is a old thread but i think i found what you were looking for in this thread:
    http://www.digitalhome.ca/forum/showthread.php?t=42509
  1. Replacing parts in the LG LRH-780 HDD/DVD recorder
    By em-t-wallitt in forum DVD & Blu-ray Recorders
    Last Post: 27th Mar 2011, 03:55
  2. LG LRH-780 DVD Drive Problems..... Solved!
    By dragon064 in forum DVD & Blu-ray Recorders
    Last Post: 4th Feb 2010, 19:59
  3. LG LRH-780 harddrive upgrade
    By canadian bacon in forum DVD & Blu-ray Recorders
    Last Post: 24th Oct 2009, 03:03
  4. DVD to H.264 - Different Running Times, Chapter Times Wrong
    By nrogers64 in forum Newbie / General discussions
    Last Post: 17th Mar 2009, 18:28
  5. LG LRH-780 remote control model number needed
    By gm3317 in forum DVD & Blu-ray Recorders
    Last Post: 27th Aug 2008, 21:20
