VideoHelp.com Forum
    hello there
    i want to encode my avi and mpg files to vcd so nero will not encode them itself...
    i don't know what to do because every program i tried encode it in a lower quality and i want to know if there a program that can just encode my files to vcd format and that's it.
    nero is always encoding and it encodes to a very bad quality.
    please help me, i tried everything, i just want to view my video files in my tv at the same quality as the original video files with the quickest encoding to vcd format.
    can someone please help? really, i don't know what else to do
    Cant be done. vcd is a low bitrate, low resolution format. See What is VCD (top left corner) for specs. I you want to preserve the quality you currently have, either convert to DVD, or get a dvd player that also plays divx/xvid avis
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    so how come nero 6 could burn my mpg and avi without encoding? i could see my movie perfectly...i burnt avi and mpg files to vcd format with nero 6 and it didn't encode and they were in a very high quality
    If they were avi, they were re-encoded. Or they were not VCD.
  5. Member AlanHK's Avatar
    That's impossible. Avi is not VCD, so if it was VCD then it was encoded to MPEG1.
    Maybe Nero just made a data CD (not VCD) and copied your files to it. That might work if your player groks AVI and raw MPEG.
    remultiplex the mpgs in TMPGEnc
    File-MPEG TOOLS-MULTIPLEX-select type as MPEG 1 Video CD
    If the mpgs are otherwise vcd compatible, the above procedure will prevent Nero from reencoding those mpgs.
  7. Member mats.hogberg's Avatar
    Best way to prevent Nero from reencoding is not to use Nero at all. Use VCDEasy to author. (Encode ??? to VCD mpg with TMPGEnc first.)
    /Mats
  1. Encoding Problem
    By mdnightsky in forum ffmpegX general discussion
    Last Post: 29th Jun 2011, 13:35
  2. How to add watermark to VCD without Re-Encoding?
    By shebi in forum Authoring (VCD/SVCD)
    Last Post: 26th Apr 2009, 09:26
  3. Tool for VCD at 2500 bitrate with No Re-encoding
    By whenloverageswild in forum Authoring (VCD/SVCD)
    Last Post: 6th Mar 2009, 11:34
  4. Encoding problem
    By silverpurple in forum ffmpegX general discussion
    Last Post: 21st May 2008, 13:31
  5. encoding problem
    By ifotel in forum ffmpegX bugs and suggestions
    Last Post: 19th Nov 2007, 10:46
