Hi!
I bought about year ago this JVC DR-M1SLE DVD-recorder (it was very expensive back then) and now it has problem, when AC plug is connected it starts up inmediately blinking 'LOADING' text and nothing happens.
I saw topic about DR-M10 loading problems because of few faulty resistors/capacitors and i decided to see whats inside my player.
I Found one CapXon 2200uF/10V capacitor whitch was bulged slightly so i swapped it to new one but LOADING is still tehere.
Should i change all filter caps from power board?
Here is pic of the power board, i replaced that bulged cap with that enermous 3300uF/50V(green cap is replacing other CapXon 2200uF/10V for a test)
Thread: JVC DR-M1SLE and 'LOADING'
You can't exchange a 3300 for a 2200, if that's what you did. You can exchange a 50 volt for a 10 volt, but the uf has to stay the same.
That 50V cap was only i had.
Have to try swapping all of those filter caps (going to buy new ones next week)
Edit:
In fact, i have repaired many PC motherboards and replaced bulged caps sometimes with much grater uf and they work just fine
JVC SR-DVM70 "Loading" problem
By dvd4met in forum DVD & Blu-ray RecordersReplies: 14Last Post: 26th Jan 2011, 12:41 -
JVC DR-MH30 Broke I think. Any suggestions. Loading error.
By hutch642 in forum DVD & Blu-ray RecordersReplies: 26Last Post: 20th Aug 2010, 19:35 -
JVC DR-M10 Loading and Repair Question
By usaf64 in forum DVD & Blu-ray RecordersReplies: 554Last Post: 24th Feb 2010, 17:54 -
JVC 'loading' repair details
By Jack Africa in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Apr 2009, 01:19 -
JVC DR-MH50S Loading Problem
By munish1000 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Feb 2009, 07:36
Statistics
Newest guides
Latest tool updates
New media comments
