VideoHelp.com Forum
  1. Member Heywould3's Avatar
    i have an issue with my display on my laptop. its the toshiba satellite 1135-s1553 and the backlight for the display turns off at random.. there is still a display but i cant hardly see it. if i close the lid and re open it after returning from hibernation it will sometimes return.. or if i plug in a crt monitor it will make the backlight return.. anyone have any idea whats causing that.. i tried all sorts of fixes.. like drivers batterys ac power etc. none have any affect.
    any help would be great.
    thanks
  2. Member edDV's Avatar
    Could be a loose connection or a failing DC to AC hardware inverter which drives the backlight. Both are service center issues.
  3. Member Heywould3's Avatar
    Thanks for the input. after reading your post i did more googleing and found lots of great info. i thought it might be something like that but having little dealings with laptops i wanted to be sure. i found an oem inverter for 45 bux and a how to on installing so worse case im only out a few bux if its a loose connection then im golden.
    its funny about how it works.. its almost always fine when the laptop is warm when its cold its a bitch.
    thanks again
  4. Member Heywould3's Avatar
    oops sorry, please delete this post.
  1. Laptop HP: No more display
    By themaster1 in forum Computer
    Last Post: 4th Jan 2011, 19:59
  2. Replies: 4
    Last Post: 26th Jul 2009, 04:58
  3. using second laptop as a video in from laptop with broken display
    By joycefitz in forum Newbie / General discussions
    Last Post: 18th May 2008, 23:56
  4. Cannot change laptop's display resolution
    By edong in forum Computer
    Last Post: 5th Oct 2007, 14:06
  5. How to display RGBHV video on a Laptop Computer
    By Valinote in forum Capturing
    Last Post: 9th May 2007, 17:56
