I have a bunch of VHS tapes some commercial, some recorded by my VCR that I'd like to convert to DVD. I bought a Canopus ADVC-100 to do the capturing. But once I capture them to DV with the ADVC-100, what's the best encoder to turn the DV files to MPEG-2? I've been doing a lot of reading and the 3 encoders mentioned in the title of this post seem to be the most popular choices. Any reason to choose one over the other? I'll been running the encoder on either a 2.6 ghz P4 or a Athlon 64 3400 machine both with 1 gig of memory under XP Home SP2.
Results 1 to 10 of 10
If I were you I would download the trial versions and decide with your own eyes.
He's a liar and a murderer, and I say that with all due respect.
Are you doing any filtering and cleanup, or encoding as is ?
Procoder Express is being discontinued. I never cared for TMPGEnc Xpress myself. Just try and see if you like it. I would go with Cinema Craft Encoder. It does a pretty good job.
Thanks for the answers, everyone. I'm new to video and DVD making so I have lot of questions. I'm aware of demo versions of TMPGenc XPress and Cinema Craft Basic but I havent seen a trial version of Procoder Express. Is one available? And does anyone know why Procoder Express is being discontinued? If is still a good program is it worth buying anyway? As for filtering and cleaning up the video I dont know how to go about that as I'm a noob.
They may have already dropped Procoder Express.
Procoder use to be a great alternative for interlace NTSC sources. CCE is the overall best solution. Mainconcept Encoder is a great alternative too: It softs a bit the picture, but on some older VHS tapes this ain't always a bad thing.
I use TMPGenc plus 2.5 for the last years and it's a great alternative for my needs. I don't like any later versions.
Why don't you like TMPGEncXpress? It is twice faster, has better resizing engine (Lanczos3), and wider importing capabilities (DVD video, HDTV etc.). I've never wanted to turn back to TMPGenc plus 2.5.Originally Posted by SatStorm
I always use external programs to frameserve, so resizing and importing various formats, is not something I need from an encoder!
Regarding the speed, well: I have an athlon XP @ 2600, so I don't have any speed benefits by using TMPGenc Express!
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
TMPGEnc XPress 4 seems okay, will ProCoder do this better?
By tluxon in forum Video ConversionReplies: 2Last Post: 14th Apr 2009, 18:16 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40 -
What happened to Procoder Express?
By lordsmurf in forum Newbie / General discussionsReplies: 11Last Post: 25th Feb 2008, 23:54 -
CCE, Procoder, Quenc or HCEnc: which one do you get better results?
By devilcoelhodog in forum Video ConversionReplies: 28Last Post: 31st Jan 2008, 21:41
