The problem concerns this awful color bar "yellow/green" at the left of the image
Take a look:
You'll see better if i modify the brightness/contrast i think so here it is:
& finally here is a cap of my scope's menu while no vhs is read...as you can see there is not this problem:
I use a 8 head vhs scope(DAEWOO),PAl/SECAM & NTSC & my vhs are NTSC
Everything is fine with my caps,colors,etc excepted this color strip problem & like i got a gang of ntsc vhs to convert I'd like to solve this problem asap.
Thanks in advance for the help folks![]()
Results 1 to 1 of 1
VHS Color Saturation Issue
By Sckinhunter in forum CapturingReplies: 1Last Post: 30th Oct 2011, 17:57 -
capture VHS with Virtualdub , color tweaks
By smartel in forum CapturingReplies: 10Last Post: 19th May 2011, 07:34 -
Need Color Correction help with old VHS video.
By mlong30 in forum RestorationReplies: 3Last Post: 1st Jan 2011, 23:27 -
Wrinkled lines aka wiggles in my S-VHS caps, help!
By veedeo in forum RestorationReplies: 7Last Post: 22nd Sep 2009, 04:58 -
A little help with VHS color correction and filtering?
By mark23 in forum RestorationReplies: 20Last Post: 2nd Jul 2009, 12:22
