i've been using my sony hdr-hc3 camcorder and noticed that after recording any footage, i'm unable to view the recorded material in any other camcorder (ie: 3ccd, ccd, etc...)!? Is this common? i had sent a wedding message to a buddy of mine and he called me up saying that nothing is on the tape, but when viewing on my hd camcorder i can view the recorded material?
Thread: sony HDR-HC3
It will only play on other HDV camcorders. Is your friend's HDV or SD?
John Miller
enosoft - high performance tools for music and video
Home of the Enosoft DV Processor - Free for personal use!
their cameras are not hdv.
I'm not even sure it plays in other Sony HDV camcorders.Originally Posted by DAIDAI
The HC-3 has a hardware downscaler. That means you could output to 720x480i DV format to a computer over IEEE-1394 (WinDV) to a DV-AVI file. Then you could store that in 20 min increments to a DVDR data disc or record back to a DV camcorder (WinDV) to a normal DV format tape.
This may all be possible with the HC-3 but I don't have one to test.
or, if you record in standard dv which is an option somewhere in the menus, iirc, then the tape should have normal minidv on it and be readable in other cams.
again, i say should as i don't have one to test with either.--
can anyone confirm my initial thread question?
I thought we did.Originally Posted by DAIDAI
You have recorded in HDV but your friends' camcorders are not HDV. Is that true?John Miller
NO others can't play a HDV tape if their camcorder isn't HDV format.Originally Posted by DAIDAI
2 workarounds explained above.
Sony HDR-HC3 - HDVSplit or winDv?
By jefftaz in forum Newbie / General discussionsReplies: 12Last Post: 20th Jan 2011, 14:10 -
Sony HDR-HC3 HDV Capture
By plugh in forum CapturingReplies: 8Last Post: 9th Aug 2009, 23:15 -
Sony HDR-HC3 1080i question for importing & exporting - will help many
By sepman1 in forum EditingReplies: 9Last Post: 4th Mar 2009, 12:57 -
I have a deal for a Sony HDR-HC3 for 350$ CDN, need quick advice
By DavidOBE in forum Camcorders (DV/HDV/AVCHD)Replies: 26Last Post: 29th Dec 2008, 12:35 -
Sony HDR-HC3/damaged Firewire port
By alegator in forum Camcorders (DV/HDV/AVCHD)Replies: 7Last Post: 19th Jan 2008, 22:08
