VideoHelp.com Forum
    Hi there
    Lately, I came across two DVD's that I can easily watch with DVDPlayer or VLC but when I try to use ffmpegX on them, it says «no video, no audio». When I look up the Titles and Chapters in the DVDPlayer an enter these values in the ffmpegX-Fields, mplayer can be startet showing the movies using mplayer. But still I can not choose audio or subtitles nor can I do a crop or anything. Do you have any idea, how I should configure ffmpegX to accept the VIDEO_TS-Folder anyway?
    Thank you, Dani
    Are these commercial DVDs with some sort of encryption or protection? ffmpegX will not handle these. Probably want to use Mac the Ripper (MTR) to decrypt/rip to your hard disk and proceed normally from there.
    Another thing to check for is the Title selection. ffmpegX defaults to Title 1, but that's not always the right choice. Using VLC, you can find out which title actually corresponds to the movie. Set that value in ffmpegX first, THEN drag the Video_TS folder on the summary window. ffmpegX does not refresh itself unless you do this little dance.
    Good luck!
    Thank you guys, both of your tips helped me a lot and solved (not only) the problem I came up with. Cheers, Dani
  1. Convert VIDEO_TS folder into video & audio ES files?
    By boxingfanmike in forum Video Conversion
    Last Post: 22nd Oct 2009, 13:09
  2. Burning VIDEO_TS folder to a DVD disc as Video not Data
    By xtaint in forum Authoring (DVD)
    Last Post: 3rd Aug 2008, 08:23
  3. No Video_TS Folder..
    By NatalieR in forum ffmpegX general discussion
    Last Post: 5th Feb 2008, 10:53
  4. Burn an already authored DVD-Video folder(VIDEO_TS)
    By jain30 in forum Authoring (DVD)
    Last Post: 12th Jul 2007, 09:02
  5. Replies: 3
    Last Post: 28th May 2007, 09:04
