i have installed vista ultimate and can`t get svcd2dvd to run here is the debug file
Version: SVCD2DVD 2.1
Build: 2.1.2474.30525
Type: System.UnauthorizedAccessException
Source: mscorlib
Message: Access to the registry key is denied.
InnerException:
StackTrace: at Microsoft.Win32.RegistryKey.Win32Error(Int32 errorCode, String str)
at Microsoft.Win32.RegistryKey.SetValue(String name, Object value)
at x3284ccece41ee22b.x2f5590cb48bb0c53..ctor()
at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426)
i have tried running in xp sp2 compatability mode but no joy can anyone please help
thanks bighun
Results 1 to 17 of 17
Thread: svcd2dvd and vista ultimate
A working version is being developed/tested right now by Chris.
Guido
Current situation is as follows:
SVCD2DVD 2.1 works on Vista (RC2 & RTM) provided that you install .Net 1.1 and .Net SP1 for 1.1 (as before), AND that you either disable UAP (and those annoying popups every 2 mins!): http://www.tech-recipes.com/rx/1358/...ess_protection or run the program as administator (use right click on the exe)
SVCD2DVD 2.5 is the current development version based on .Net 2.0. With this version you will not need to install and .Net stuff on Vista. It is work in progress and will be released as soon as iron out a small issue.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
thanks chrissyboy just back from glasgow so i will try tomorrow
cheers bighun
I did the disable thing. But mine was called "Disable UAC".
It installs fine, but I get this error:
I am on full release Vista UltimateCode:Version: SVCD2DVD 2.1 Build: 2.1.2474.30525 Type: System.IO.FileLoadException Source: SVCD2DVD Message: The located assembly's manifest definition with name 'AxInterop.CodeLock' does not match the assembly reference. InnerException: StackTrace: at x3284ccece41ee22b.x2f5590cb48bb0c53.x85601834555fb7d5() at x3284ccece41ee22b.x2f5590cb48bb0c53..ctor() at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322395(String[] xce8d8c7e3c2c2426)
uninstall and then reinstall. This time right click the msi file and choose "run as administrator".
I am having the same issue with Vista, SVCD2DVD and HDTV2DVD. I have reinstalled .net 1.1 and SP1 numerous times, I have disabled UAP and ran both programs as administrator. Nothing seems to work. Every time I start either application, i get the error that it can't find the proper runtime. I am open to any solutions for a fix. Heck, I even tried installing .net 3 that just came out.
There is no obvious runtime version on your vista build to run svcd2dvd. Can you unzip the attached to the SVCD2DVD folder and retry running the app?Originally Posted by shupp872
svcd2dvd.exe.config.zipSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Great, I will try this when I get home. Out of curiosity, can I rename the file for HDTV2DVD and put it in the HDTV2DVD folder to make that work too? (I really only need the functionality of HDZTV2DVD, but will settle for SVCD2VD).There is no obvious runtime version on your vista build to run svcd2dvd. Can you unzip the attached to the SVCD2DVD folder and retry running the app?
Thanks Chrissyboy.
yes - that should work too.
ChrissyBoy,Originally Posted by ChrissyBoy
I did what you mentioned and it does allow both programs to run, thank you. However, I am unable to "drag and drop" any files into the programs. This isn't such a big deal in SVCD2DVD since there is an "add asset" menu. However, in HDTV2DVD, there is no menu for this, and the only way to get assets loaded is via drag and drop.
Any ideas?
Same problem as above... dropped the file into the install folder and ran again and still got the problem: ran prog as administrator and got -
Source: SVCD2DVD
InnerException:
StackTrace: at x3284ccece41ee22b.x2f5590cb48bb0c53.x85601834555fb 7d5()
Now, I DID NOT disable UAP before running as I quite like the annoying popups because it is a line of defence against any malicious software and I'm not prepared to lose it right now.
So... does that mean waiting for v2.5?
I love this proggy and found it to be one that I really "can't live without" using it every day... please stop me having to regularly reboot to XP so's I can use it
BTW: Subtitle support... please, please and please!
You should still be ok... Did you install as administrator? i.e. run the msi as administrator?
ChrissyBoy,
Any thoughts as to why I would be unable to drag and drop files into either program from within Vista? Without being able to drag and drop, HDTV2DVD is unusable.
Thanks. Btw, the file you posted works great getting these programs to load in Vista, thank you very much. I still have to run them both as administrator, which isn't a problem.
Not yet - i will take a look at HDTV2DVD when i get a chance...
Thanks for the help... it is now installed in Vista but when I try to run the program I get the splash screen come up and then nothing else
Any ideas how I can actually get the prog to run?
did you go through the registration process okay? if so drop me an email and we will attempt it "off line"
Windows 7 Ultimate - Can't load assets in SVCD2DVD
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th Jan 2010, 10:54 -
virtualdubmod and vista ultimate
By volam1 in forum Video ConversionReplies: 1Last Post: 25th Sep 2009, 10:09 -
try to ge VLC work with Vista ultimate
By volam in forum Software PlayingReplies: 13Last Post: 19th Jun 2009, 00:19 -
Using DVD43 with Vista Ultimate 64?
By tigertribe in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2008, 14:09 -
How to install Vista Ultimate 64 with raid5
By mysts in forum ComputerReplies: 3Last Post: 4th Aug 2007, 20:49
