Hi... this may be really basic but I have a folder of .vob, .bup, .ifo files that I am trying to put on a DVD (these files are a video of an NFL football game... I converted a divx format of the game I think to get these files using WinAvi). I'm not sure what the final step is to get it onto DVD? The WinAVI process gave me an AUDIO_TS folder (which is empty) and a VIDEO_TS folder (which has these .vob, .bup, .ifo files) which are all contained in one dvd_0 folder that WinAVI created. Not exactly sure what to do at this point? From the main menu of WinAVI, I chose the "Burn your DVD" option chose the Add Movie -> DVD Movie option and chose the dvd_0 folder to burn, is this correct? I had problems burning when doing this. I also have Sonic MyDVD... is it possible to convert vob, ifo, bup files to DVD using this software as well? Any help appreciated as I don't really know what I'm doing thanks!!!
Read this....Originally Posted by Osei
http://www.videohelp.com/dvd#struct
The menu on the left side of your screen has links to all kinds of neat stuff 8)
You should already have a compliant dvd structure (and i say "Should" for using WinAvi anyways
You should be able to burn what you have to a dvd with any dvd video burning app.Originally a member since 2001, LONG LIVE TARAN's!!!
If you already have a VIDEO_TS folder with all the required VOBs, IFOs and BUPs, you have a DVD. Just burn it to disc. You can use the freeware ImgBurn for this: http://club.cdfreaks.com/showthread.php?t=197530 Other burning programs may also be able to do this. Hopefully WinAVI hasn't made a mess of the files. It's not too popular around here.
For the DVD stucture and format, see:"WHAT IS' DVD to the upper left.
How do I make a dvd data disk from these vob, bup, and ifo files?
By DHarry in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2011, 04:23 -
How do I convert VIDEO_TS containing VOB, BUP, IFO files to a single file
By Firesmith in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2010, 11:14 -
Function of .IFO .BUP .VOB files on a DVD?
By brassplyer in forum Authoring (DVD)Replies: 6Last Post: 14th May 2008, 21:27 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 05:31 -
*S.O.S* No Sound when burning VOB-IFO-BUP Files to dvd
By Zaii in forum Newbie / General discussionsReplies: 3Last Post: 30th Jul 2007, 04:46
Statistics
Newest guides
Latest tool updates
New media comments
