VideoHelp.com Forum
    I've read some posts in here about issues with Media player classic and unfortunately I've found no solutions
    here's my dilemmna....b4 i reformatted my pc everything worked fine...i could take an avi w/ a .srt sub file and put it in convertxdvd and it would convert the file to dvd format and the subs would be play great on my dvd player....I could also load up the dvd and the avi file in media player classic and the subs would automatically play......now that i've reformatted....nothing....what i find strange is that i can open that same avi file in Nero Showtime and it plays the subtitles fine....I've installed ffdshow...xpcodec pack....k-lite codec pack...vobsub etc...i've went into the settings of media player classic and have changed the settings to vmr 7/9 etc...an had no effect
    can anyone steer me in the right direction? this is frustrating
    moontrash
    Check that VMR7/9 are actually being used.
    how do i go about doing that?
    i reinstalled every codec w/ xpcodec and also ffdshow....i finally got the subs to work but i had to enable them in ffdshow but the problem is now that these subs play in all the avis i have now...im assuming i have to get rid of the avi and dissable them in ffdshow....i even installed vob sub....
    i redid this avi w/ convertxdvd and they are now showing up in the dvd file when played...what will i have to do to make subtitle files...srt....show up for each indivdual avi in stead of having to load them manually?..i have checked all the options that say load automatically
    moontrash
    UPDATE...I burned the dvd and the subs arent there....whew...
    MPC gives you access to the filters in use. Simple check to see what renderer is being used. You can also import the graph into graphedit if you want a visual representation.
    i now have to manually load the subs to get them to work...also have to set up ffdshow to make them work..this is strange....i looked at gspot to see if i had the proper coedcs etc....i found one missing....vfapi.dll....i remeber tmpg needed this for subs or something similiar...i tried to install this and had no luck also....just keeps coming up missing file..
    You only need the VFAPI reader codec if you want to create fake avi's via VFAPI for frameserving. For that I'd suggest using AVISynth instead. So basically you don't need it.
    ok..thanx for that......funny thing is that i found the vfapi dll in the system32 folder.....dont know y gspot says its not there..hmmm
    moontrash
  1. Media Player Classic - subtitle
    By pchan in forum Subtitle
    Last Post: 16th Nov 2010, 07:37
  2. Problem using Media Player Classic home cinema player
    By True Colors in forum Newbie / General discussions
    Last Post: 18th Apr 2010, 07:30
  3. Streaming FLV in WM Player or Media Player Classic
    By jlz901 in forum Video Streaming
    Last Post: 21st Mar 2010, 11:09
  4. Media Player Classic (Subtitle Problem) !
    By Bahez in forum Software Playing
    Last Post: 2nd Jan 2009, 06:19
  5. Replies: 4
    Last Post: 1st Aug 2008, 22:49
