From the tools and other places to install Lame it says to right click on the .inf file and click install.
However I dont have any .inf file only several .html files, lame.exe, lame_enc.dll and lame.css
What am I missing?
If I install this can I use it from within any editor??
Results 1 to 11 of 11
From the tools section click on the "Download" link for Lame MP3 and on the Rarewares website you need to download LAME 3.97 Release ACM.It will contain the INF.
I'm not too sure that it can be used in all editors but I certainly know that VirtualDub will list it.Audio Editors like Goldwave just require you to copy lame_enc.dll to its programs folder.~Luke~
Thanks laspis59.....I installed it ok, but vegas doesnt seem to recognise it when i got 'render as' which is fair enough but I also cant find it in virtual dub. Do I have to do something special for VD?
Do you have "Hide Extensions for known file types" ticked in your Folder view options in Windows ? If so, check the folder for a file type "setup file". This will be the inf.
I dont know about Vegas but in VirtualDub have you clicked Audio>Full Processing Mode and looked at Compression...?Originally Posted by Rudyard
It should list "Lame MP3"~Luke~
Gunslinger - I downloaded the wrong thing, I have installed it now (there are other files at the top of the list on the linked web page which I mistook for what I needed)
laspis59 - My virtualdub doesnt have an audio section. I use virtualdubmod because I thought it included everything, is there an audio version or VD or do I need the original??
Virtualdubmod : Streams -> StreamList. Right-click and select Full Processing. Right-click again and select Compression.
Ok I downloaded normal virtualdub and found the audio tab.....it seems virtualdubmod all inclusive is not all inclusive!
Thanks heaps I got it to work now.
Ahh thanks for that - wonder why they hid the audio as it seems so much easier in normal virtualdub with an audio tab?Originally Posted by guns1inger
Thanks to both of you all is working now!
In many ways, VDM's audio is easier to use, once you find it. Especially when you are working with multiple streams or stream replacement.
guns1inger - I've been searching for that setting for years! Thanks, man.
Lame MP3 Encoder on Vista x64
By edt in forum Newbie / General discussionsReplies: 19Last Post: 26th Mar 2012, 17:56 -
MP3 (LAME) in Avidemux
By moiz in forum AudioReplies: 2Last Post: 18th Feb 2012, 10:18 -
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 16:13 -
how to setup automkv to use lame mp3 encoder instead of fraunhofer
By deejay.2001 in forum Video ConversionReplies: 0Last Post: 1st Aug 2009, 06:42 -
Problem Installing Lame - I think I am going mad!
By Janusian in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 15:15
