I have been using ffmpegx to convert AVI files for use on a DVD player. I had been using DVD ffmpeg as the target format. This had been converting files to .avi.ff.mpg and also .avi.ff.mpg.DVD. I don't know why it did this, but it worked when I burned the DVD with the DVD files. For no obvious reason to me, it no longer converts to the .avi.ff.mpg.DVD format. What's up?? Thanks for your help.
Thread: Target format gone?
Are you saying that you do get the .mpg file, but not the DVD folder? If the Author as DVD option is checked (as is default, I believe), then something went wrong in the authoring, which would be mentioned in the log. Posting that output might help resolving this.
Alternatively, you could try the authoring tool, in the Tools tab.
winff not following target bitrate
By xero273 in forum Video ConversionReplies: 0Last Post: 28th Dec 2011, 21:23 -
AVI To DVD Which Target Format?
By Bunky in forum MacReplies: 10Last Post: 30th Oct 2009, 07:41 -
VHS ripping - what's the best target format?
By JaVo2004 in forum Newbie / General discussionsReplies: 25Last Post: 1st May 2009, 15:41 -
FFmpeg changes Target format settings after dropping a new Source file
By GvdB in forum ffmpegX general discussionReplies: 1Last Post: 2nd Sep 2008, 11:59 -
What Target format
By yomamaho in forum MacReplies: 3Last Post: 9th Aug 2007, 19:44
Statistics
Newest guides
Latest tool updates
New media comments
