I have connected my dvd via component ,and theres no color.I have another dvd player so i also connected it to the same tv ,and theres same problem,the picture is black and white.What could cause it.
Results 1 to 13 of 13
Are you using NTSC output settings on the DVD players into a NTSC TV? If for example, your DVD player output is set for PAL, and you have a NTSC TV, the result is often B&W.
Aside from that, sounds like the component input on the TV is faulty or your color settings for the component input are not adjusted properly. Most TV's allow different color/brightness settings for each seperate input.Google is your Friend -
What is the model number of the TV set? Are the red-green-blue inputs marked Y, Pb, Pr or Y, Cb, Cr?
DVD player setup menus should be switched to "Component" output and then interlace or progressive scan (depending on the TV). -
Yes at the back it says Y,Pb,Pr.Model is PANASONIC CT-36D12DF 36" CRT tube.I have a Philips dvp640.In the options i set for NTSC and Component output(i also used another dvd thats only NTSC).
The DVD player should set to component video and interlace for that TV set.Originally Posted by vinland
Thx for help.How do i change the options to interlace?
In the video settings menu there is a setting for progressive scan, I belive the options are on/off. You would want off.
^^^Thats excatly what i did,and the result is the same
In the dark the blue/green cables (or the plugs specifically) look the same. I've noticed this when switching cables around. I always need a flashlight otherwise the blue and the green look the same to me.
Maybe you have them swapped? You know blue cable plugged into the green and the green cable plugged into the blue or something like that. I would double check the connection. If that doesn't work try another set of component cables.
If you have used multiple DVD players and cables and are sure of the menu settings and the connector colors are matched, then the suspect is the TV itself.
Next best connection is S-Video. -
That's it. You have no more info for us or a "I fixed it" or a "it's still buggered up" or ... ???Originally Posted by vinland
I tried everything that was suggested and the result is negative.Something must be wrong with my tv
Converting a color video to black and white apart from one color. Possible?
By SteveLock in forum EditingReplies: 7Last Post: 23rd Feb 2009, 08:04 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX bugs and suggestionsReplies: 0Last Post: 2nd Feb 2009, 21:16 -
[color=red]how do you play region 2 dvds on this setup[/color]
By j821977 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2008, 14:58 -
Calibration of an 8 bit digital component editing system using color bar.
By edDV in forum Video ConversionReplies: 4Last Post: 20th Feb 2008, 12:48
