I've been using TMPGEnc for years now, at least 4, and I really love it. However, recently, something's happened and I don't know what. For some reason, when I try to convert videos (WMV and AVI [15-25 minute files]), it takes 2-3 times longer than usual...Many times, it freezes half-way through the conversion. Can anybody help me? I haven't changed the settings since I configured it the way I like it, and it worked just fine for years. I'm so confused. BTW, it makes no difference whether or not I use VBR...Even if I switch back to CBR, it still takes MUCH longer than usual.
Oh. And its not just this computer I'm on now...It's the same on my other, newer computer.
Results 1 to 9 of 9
WMV's are hard to convert. Try MediaCoder or ConvertXtoDVD.
A really noisy source can slow down encoding.
But I seem to be having the same problem with ALL files, also.Originally Posted by Barnabas
What's the source of the avi files? Capture from old video tape? What sort of avi compression?
Various sources. I've downloaded them off the internet..
If you were having this problem with stuff you capped yourself, that's one thing, but stuff from the Net could be anything.
I suggest you try MediaCoder or ConvertXtoDVD on the problem files.
I have them all on 0 priority.Originally Posted by Tad Farrar
M2TS conversion and playback slower than Molasses in January
By HighVoltageMiner in forum Video ConversionReplies: 2Last Post: 13th Jan 2010, 15:45 -
Slower conversion with Windows 7?
By gooberguy in forum Video ConversionReplies: 2Last Post: 3rd Nov 2009, 20:27 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40 -
TMPGEnc makes deep/slower sounding audio
By awesomer in forum Video ConversionReplies: 8Last Post: 28th Oct 2007, 00:46 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
