VideoHelp.com Forum
Thread: VGA OR S-VIDEO
    hi all
    i want to run my xbox360 through my projector .i have 2 optons either VGA OR S-VIDEO which wouldbe the better?
    many thx
  2. Member yoda313's Avatar
    My guess would be svideo. I don't have a 360 but chances are svideo would be sharper.
    Just try both and find out. You won't harm anything that way by trying.
    The xbox 360 is capable of hidef output. VGA will be far better if you're running hidef and and your projector supports it.
    hi
    thx for replys , the projector does not support h/d so its vga (computer input) or the s-video
    which would be better
    thx again
  5. Member MOVIEGEEK's Avatar
    My guess would be VGA because it is similar to component but the only way to find out is to try both.
    Do you mean VGA the 640x480 video resolution, or are you talking about VGA the connector and cable? A VGA port and cable can carry over 2048x1536.
    The question is what resolution is your projector? Even if it's only 640x480 the VGA cable will likely be better because RGB carries all three color channels at the same resolution. S-video has the color channels at half (at best) the resolution of the intensity channel. So your colors will be much sharper with VGA.
    On the other hand, if your projector is really cheap and only has 320x240 resolution, both may look about the same.
    There are other factors too -- like whether the xbox can output at your projectors native resolution, what it's optimized for, etc.
    There are too many unknowns to answer your question definitively. You'll have to try both.
  1. Intel GMA HD/Core i3 - VGA has TV-out/S-video-out/component-video-out?
    By Morality124 in forum Media Center PC / MediaCenters
    Last Post: 9th Jan 2011, 00:44
  2. RCA composite video on Wii but component video and VGA inputs on tv
    By shashgo in forum Newbie / General discussions
    Last Post: 22nd Aug 2010, 21:48
  3. Replies: 5
    Last Post: 22nd May 2010, 21:57
  4. Replies: 4
    Last Post: 22nd Mar 2008, 10:42
  5. Replies: 1
    Last Post: 20th Mar 2008, 13:57
