I am coming from an HD Source (over the air network TV), and my destination is DVD.
The source: DirecTV HD Tivo 10-250 (has component, s-video, and composite)
My DA Converter: Canopus ADVC-100 Analog Digital Firewire box
Software: FCP 4.x and DVDSP 3.x
My question is this.... how do i "play" the show on the DirecTV box into my DA box (thru s-video) and maintain 16x9 and what settings do i use in FCP when capturing to retain these settings... so that i can save my show in the aspect ratio intended.
I have done this many time with my Standard Def box with 4x3 material.
I realize this is using the analog approach and I'm fine with that.
Thanx in advance.
Final Cut Pro 4.5 HD
DVD Studio Pro 3.x
Canopus ADVC-100 DA Converter
The high definition material will first have to be downconverted to 480i before the Canopus will recognize it. My Motorola DVR from Comcast does downconversion in the box but it unfortunately letterboxes high definition material and outputs 4:3 letterbox. To overcome this, I route the high definition material through a JVC D-VHS machine, which downconverts but does not letterbox. From there, the signal goes into the Canopus, and out to Final Cut Pro (or most times, iMovie HD). In FCP there is a setting for DV Widescreen (select that).
well its going thru s-video - so its downconverted to 480. i guess my question is if the material is NOT letterboxed and actually anamorphic, will the canopus ad converter PRESERVE the anamorphic?
DVD Studio Pro 3.x
Anamorphic is a flag; the Canopus will ignore the flag being sent down your S-Video feed. However, you can always re-set the flag in your DVD authoring program.
If you want to work with the video and view it in its proper aspect during editing, just make sure you import into Final Cut using the DV Anamorphic sequence present/capture preset, or the DV Widescreen dropdown in iMovie HD.
That was the exact answer i was needing. Thank you VERY much!
DVD Studio Pro 3.x
Help with keeping quality for archiving my video files. Interlace source
By drewzor in forum Video ConversionReplies: 11Last Post: 8th Mar 2010, 18:32 -
DVD Tv Episodes to PC and keeping Anamorphic 16x9
By saber001 in forum DVD RippingReplies: 7Last Post: 16th May 2009, 20:24 -
16x9 letterbox instead of 16x9 pan and scan
By CogoSWSDS in forum Authoring (DVD)Replies: 4Last Post: 30th Mar 2009, 04:08 -
Confused by the aspect ratio coming out of my camcorder: 720x480 != 16x9
By kirilius in forum Newbie / General discussionsReplies: 9Last Post: 6th Jan 2009, 14:05 -
Outputting to DVD from 16x9 source
By yadda in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2007, 21:02
