VideoHelp.com Forum
Page 2 of 2
FirstFirst 1 2
Results 31 to 55 of 55
    Mmmm, yeah.
    Quicktime Pro's looking better all the time.
  2. Member Soopafresh's Avatar
    Pretty good idea if you want to be safe. Too bad their h264 decoder is crap.
    One last thing - I found a different version of the Qtsource plugin. Give it a try ?
    Let me know how it turns out
    qtsource.zip
    Also, before you break out the credit card:
    I uninstalled Quicktime Player 7 and installed Quicktime Alternative in a folder with the same name as before, Quick Time, in Program Files. I opened the process script and F5. I got the sign "is a funny thing" but when I press play nothing happened. When I move the frame slider frame by frame I can see the background changing. When I move it faster nothing happens. Media Player classic plays my quicktime movie files in the same jumpy manner as Quicktime 7. When I press start it seems like a downloader window flickers for a moment in the toolbar at the bottom. Still positive?
  4. Member Soopafresh's Avatar
    jan.t - Try the different Qtsource file I posted above. Yes, that's a really good sign.
    Try your AkramochHamanScript.avs script next.
    Which script? I have changed it a couple of times. But I will try them one bye one.
  6. Member Soopafresh's Avatar
    A=QTInput("F:\MOV_WAV_files\AOHqtmov.mov", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0)
    B=QTInput("F:\MOV_WAV_files\AOHqtmov2.mov", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0)
    Combined=A+B
    Return Combined.Spline36resize(720,576)
    Well... MY VIDEO IS THERE!!
    But I canīt play it. Only drag the slider and view every frame for itself.
  8. Member Soopafresh's Avatar
    That's good ! GREAT !
    You can play it, BUT you need to install an external player and tell AvsP where it is.
    I'll post those instructions in a little bit, but now, feed the script to CCE ! Good luck!
    Edit: Download this, includes mplayer.exe to view the video from AvsP and AVS2AVI, which also is a good little app - let's you encode to Xvid, Divx, etc from within AvsP.
    http://www.bestsharing.com/files/vwW...nocss.zip.html
    After you unzip, put them all in the same folder and point to Mplayer.exe and Avs2AVI.exe - doesn't matter where you put them, as long as you specify it in AvsP.
    The setup screen in AvsP is Options-->Program Settings
    Remember, AvsP is just an editor to preview your Avisynth scripts (but a pretty good one). Once you're happy with the image in AvsP, save the script with an .AVS extension and load it into your favorite Mpeg encoder or any other program that allows .AVS input.
    I have encoded the script (the whole movie in mpv!) and viewed it in Nero. I have also viewed the avsscript exactly where the joining was done and it is perfect.
    I am very very glad.. NO! I FEEL RELIEVED! This was probably the only mov joiner I could ever get to work in an acceptable way. I have been at both the avid forum, doom9.org forum and contacted cce support, searched the web, and NOONE had a solution at hand. Liquid, the creator of dvdauthorgui recommended this place, and.. well, you KNOW you saved my workflow right now!
    Now, is there a possibility that I can buy you a nice dinner this weekend? (and a beer of course)
    I will come back with some concluding questions..
    something is wrong with this page. it doesnt update my posts correctly.
  11. Member Soopafresh's Avatar
    Thanks for the kind words. Do you know any blonde Swedish women ? If anything, you can donate to Videohelp.com, and I'll take you up on that beer the next time I'm in Stockholm.
    jan.t - clean out your cookies from your web browser and log back in.
    Great Forum...
    Hope this topic is not dead. I followed the instructios my first time and got everything to work. I am using Windows Media player as the player and when i hit F5 it shows the merged movies and plays them but with NO SOUND!
    Just wondering if i missed something to get the sound to work?
  13. Member Soopafresh's Avatar
    Try the change below. Your system might be a little underpowered to playback in realtime, especially if that fixes the audio for you.
    Thanks you for the quick response....
    I changed the settings and tried to view, F5.
    Media player started and then it errored out
    Went to Link
    [/img]http://www.microsoft.com/windows/win...nalid=800401F0
    Set back to false and it run video but no audio.
    Don't think computer is underpowered, dual processor.
  15. Member Soopafresh's Avatar
    Whoopsies....
    Well, you could try the following, although I've never tested it out.
    A=QTInput("file1.mov", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0)
    B=QTInput("File2.mov", color = 2, quality = 100, audio = false, mode = 0, raw = "yuyv", info = 0, dither = 0)
    video=A+B
    audio=directshowsource("file1.mov")+directshowsour ce("file2.mov).killvideo()
    AudioDub(video,audio)
    If that doesn't work, you could go back my original suggestion but try a different player that supports .AVS scripts such as Gmplayer
    http://tirnanog.fate.jp/mirror/mplay...r2007.04.02.7z
    or MPUI (cleaner looking, but slightly slower)
    http://www.freewarefiles.com/downloa...rogramid=21340
    Wohoo, almost there.
    Scraped out Windows Media Player and downloaded the GMPLAYER. Played and no sound.
    Switched audio=true and sound.
    Bad news - sound is not in time with the video. Used the video player settings and still unable to get sound to synch. Any ideas? What is the mode setting after audio? Is there a place to get the commands for AVISYNTH. This is my first time using the program...
  17. Member Soopafresh's Avatar
    Oh, so close, yet...
    I see you've got low cpu horsepower, so it wouldn't surprise me if the A/V was off. I should say this method of playback would stress just about any processor.
    BTW, there are tons of better looking skins for that player. Never really liked the default one it comes with.
  18. Member
    Soopafresh, I have always wanted to know how to edit video with a programming language and not use Adobe Premier and other video editors. They are great applications but require a good bit of resources and like I have never had great hardware.
    I had recently purchase a point and shoot camera and take lots of video with it. I needed to join the .mov files and I found this post. You have shared the important thing how to setup the development environment. And this can be such a mystery and frustration when you first start to develop. Your great instructions and screen shots you provided have been such a help. There are many forums but this one with you as a functioning member really works. Your screen shot and thorough responses are a clear indicator that you are experienced and knowledgeable. Thanks again if you are ever in North East USA I would love to buy you many drinks. Helpful developers like you come along very infrequently.
    I just needed to let you know, thanks Lex
  19. Member Soopafresh's Avatar
    Hey, thanks lex for your kind words
    Try using Mpeg Streamclip
    I will reinstall and do it from the beginning.
  22. I searched for a free solution for a while tonight and free video joiner finally solved it: http://www.free-video-joiner.com/download.html Other solutions, such as Quicktime Pro and most of the "freeware" that I found didn't work.
  23. There's always been an easy way to do this since xvid4psp launched.
    Attached Thumbnails Click image for larger version
  24. can you explain how to actually combine mov files in that program.
    I downloaded it does NOT Look like yours. I added my 12 files. but when I click encode it makes 12 copies and not 1 copy with all 12 files together. IE merge.
    I click file and then JOIN FILES
    I had to then click + and add each file (no drag drop here) and it APPEARS to be doing it I get a preview of one single file of all 12 but I see no wya to "SAVE" this to a file. again if I hit encode it makes 12 files
  25. Last time I checked the new avisynth 3.x is YV12 and no longer YUY2. you would need to add converttoyuy2() at the end of your sources.
    If you want to see what I've done with my videos,
    check out my video work on youtube, http://www.youtube.com/user/duhmez/
  1. Replies: 2
    Last Post: 11th Mar 2012, 19:42
  2. Join MOV Video from command line
    By parisisal in forum Editing
    Last Post: 19th Feb 2009, 10:59
  3. Join mov files and upload to youtube
    By neelapala in forum Editing
    Last Post: 23rd Dec 2008, 11:09
  4. Replies: 0
    Last Post: 19th Sep 2008, 03:37
  5. Replies: 1
    Last Post: 26th Jun 2007, 08:16
