VideoHelp.com Forum
    Just installed the latest build of the XviD codec and did a test-run on a 30 second MPEG2 with avi.NET.
    The results are great - the latest version of avi.NET is fab - but...
    When I use GSpot v2.21, the resulting avi file is listed as being coded with DivX 5.0.
    What have I done wrong? Is this necessarily detrimental anyway?
    p.s. I did de-install the previous XviD codec, before installing the latest build.
  2. Member mats.hogberg's Avatar
    That may be a deliberate thing in avi.net, to make it more playable on standalone players.
    /Mats
  3. VH Wanderer Ai Haibara's Avatar
    What happens if you update GSpot to version 2.52 or the latest 2.60 beta (I think it's beta 3, at the moment), and scan the file? Some programs like GSpot may need to be updated to recognize the newest versions of some codecs. I don't think XVid's FourCC would have changed, though...
    From the Xvid Configuration dialog press Other Options (near the bottom). Select the FourCC you want.
    It's already set as "DIVX".
    I upgraded my version of GSpot but it still says DivX.
    I've now manually changed the FourCC of the file now anyway, using Nic's FourCC Changer.
  6. Member mats.hogberg's Avatar
    If avi.net is set to use DIVX as FourCC, it's hardly surprizing GSpot reports it as DivX, is it? As some players insists on only playing the FourCC DIVX, it makes sense to disgiuse XviD as DIVX.
    /Mats
  7. VH Wanderer Ai Haibara's Avatar
    Ah, so avi.net has the ability to do that? Okay. I don't use it, so I didn't know.
  1. Replies: 4
    Last Post: 10th Oct 2011, 11:51
  2. StaxRip version compatible with .NET Framework 3.0?
    By BNA84 in forum Video Conversion
    Last Post: 5th Feb 2010, 17:14
  3. Net Framework...which version should i install?
    By ricardouk in forum Computer
    Last Post: 18th Jan 2010, 12:07
  4. Replies: 10
    Last Post: 29th Oct 2009, 14:18
  5. Replies: 5
    Last Post: 17th Jun 2009, 12:39
