I have nero 7 and I burned 30 or so svcd's and the animated menus and chapters don't work just FF. No matter what I couldn't get them to work.![]()
Anyway, I now have VCDeasyand would like to know how to create a animated chapter menus. Is there any thing out there that I can use in conjuction?
Jobesd
Thread: SVCD Animated Menu
Maybe the only one capable of motion menu creation for SVCD is TSCV software:
http://www.tscv.org/download.htm
Detailed guide for it can be found at doom9.org in Guides section/VCD & SVCD guides/TSCV guide.
Whatever reasons you have for STILL burning svcd it will be inevitably better and easier to change files to 1/2D1 (356x576), rather than 480x 576, resolution as these can then be used as valid files in any DVD authoring program. SVCD menus cannot have most of the features of full DVD menu's. Maybe you dont have a DVD player tho?
hard to believe as they are being given away with full james bond box sets. or maybe no DVD burner. Burners and players cost about the same as one months internet access?
You have kept this forum section alive for a few months more
The electronic components of the power part adopted a lot of Rubycons.
The best quality way to do animated menus in VCD or SVCD (if your stuck with going that route) is to create the video clip in a regular NLE (AVID, Vegas, Premiere, AE, Ulead, etc.) using the Menu Still as background and doing whatever you'd like (3D moves, warping/morphing, simple slideons, video thumbnails, etc) with it and rendering to a finished file (to later be converted to MPEG for authoring w/VCDEasy).
Now, there are consumer-friendly shortcuts, like apps that do motion menus for DVD. If one of those will output a 1/2D1 pre-rendered MPEG2 file, you could take the .m2v portion directly into VCDEasy for use as a CVD (it may complain though). If you go from this route, you will have to SRC the audio from 48kHz to 44.1kHz and reencode to .mp2.
Well, I am on the road alot and my laptop doesn't have a DVD burner. However, after you mentioned it. I just started wondering what I was doing with messing with a dinasour. STUPID. Anyway, I am heading out and picking up an external DVD burner. I guess that would solve the problem quickly.
Jobesd
Creating Animated Menu images
By DesertAvenger in forum Authoring (DVD)Replies: 4Last Post: 15th Sep 2009, 23:30 -
Deconstructing, translating, then reconstructing an animated menu
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2009, 17:06 -
GUI for dvdauthor Animated Menu Buttons
By deco81 in forum Authoring (DVD)Replies: 3Last Post: 6th Dec 2008, 18:41 -
animated menu w/ ConvertXtoDVD
By WhiteKenny in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2008, 15:13 -
Animated thumbnail (playing thumbnail) in DVD menu??
By blizzery in forum Authoring (DVD)Replies: 13Last Post: 9th Nov 2007, 01:46
