Hi Guys and Gals....
I had this problem which bugged me for a while....
I bought a Karaoke vcd (VCD A), which one of the song (music08.DAT)had problem which jammed halfway thru.
As I loved that song very much, I managed to find another different karaoke (VCD B), which had that song with no problem at all in it.
Now here's problem come in.... I like to make a new VCD which is everything (with it menu page )in VCD A untouched except that I will overwrite the spoilt (music08.DAT) with the good one from VCD B....
I tried using Nero burn to burn VCD A to a CD-RW disc then try to rewrite it with music08.DAT from VCD B however was unable to do so......
Then I tried to copy everything of VCD to my desktop and overwrite music08.DAT, and burn it to a disc...but it cant be read in the VCDplayer due to the format is CD-ROM and not VCD....
Can anyone guide me to make the prefect ver for my VCDplayer to read the disc....
Thx in advance~~
One way that should work is to use VCDGear. (Freeware).
First get all your music tracks from both discs into a folder on your hard disc, using VCDGear's "dat to MPEG" function. Give the files appropriate simple names so you know which is which.
Then use its"video-CD" mode (select VCD, not SVCD), choose "MPEG to cue/bin" to select all these MPEGs and then create the image file (as a cue and bin). Use Nero to burn the image.
This won't give you a menu, but you'll be able to skip from track to track with the usual remote buttons.
Thx for the tip AlanHK, but I would really like to have menu too...
hope anyone out there can help me out. Thx~
After you convert .dat's to .mpegs you can use VCDEasy (free version of it can be found on this site) for authoring a new VCD with menu and chapters.
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 14:53 -
How do I solve this file joining problem?
By A_Shepherd in forum EditingReplies: 30Last Post: 2nd Sep 2010, 13:27 -
Can you solve my choppy video problem?
By imrealdumb in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2009, 20:44 -
Installing ffdshow to solve codecs problem?
By giunghi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2009, 05:42 -
Unable to solve a boot problem, really need some HELP.
By blinky88 in forum ComputerReplies: 5Last Post: 24th Apr 2009, 16:17
Statistics
Newest guides
Latest tool updates
New media comments
