I have a DVD I ripped in IFO mode. Now, in AutoGK, I select the IFO as the source and I get the pop-up that tells me to select a PGC. There are five PGCs, one is 17 minutes, the others are approx 55 minutes. I selected #1, and added it to the queue. Then I went through the process again, selecting #2 and changing the output filename. Etc and so on.
Well, upon completion, each output file is the same, they are all the same 3 hour+ file. What's up with that? I don't mind much since this is the way that I would have done it anyway, but let's say that I wanted each "show" ripped separately, how would I do this?
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card
Well generally speaking when you RIPPED in IFO mode it should have allowed you to RIP each episode separately (though not always depends on how the DVD authoring was done).
I've noticed when doing this that when the IFO file is opened in autoGK it still has all the PGC's or "streams" as I call them "present" but only the one you ripped will actually be there.
Granted I haven't done many episodic type DVD discs but I do seem to recall some allowing to RIP just the episode you want whereas others seem to RIP all the episodes as one big chunk ... I don't know if that comes down to settings in DVD Decrypter or if another ripper would be needed. For instance I've heard good things about using RipIt4Me or maybe PgcDemux although I have to admit I haven't used either yet I've read good comments about both from other experienced users.
Good Luck !!!
Ripbot behaving strangely
By nikemouse in forum Blu-ray RippingReplies: 3Last Post: 6th Nov 2009, 00:08 -
Pgc edit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 12th Jan 2009, 13:05 -
I Need New Burner Recommendations Badly
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Sep 2008, 16:05 -
PGC edit
By kshavo in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2007, 18:47 -
framserve PGC
By kurbads in forum Newbie / General discussionsReplies: 10Last Post: 3rd Jul 2007, 08:03
Statistics
Newest guides
Latest tool updates
New media comments
