i got a problem with my samsung ht-q20 dvd home theater. i recorded some dvds on my computer but it is not possible to show these dvds on my samsung dvd player. the systems says :"play prohibited".
can someone help me? what is the cause of the problem? on my pc the dvds runs without problems....
thanks from germany
Results 1 to 10 of 10
Can these DVDs play on other DVD players ?
yes, the dvds are playable on other players!
its not disc senistive its the css if you open an iso or image file and copy it to the hard drive then re burn with nero recode it will work on the ht-q systems no probs hope this helps.
i have two samsung dvd players one high def and the htq system the high def isnt as fussy as the htq system its the firmware they have used in the htq that makes it fussy about the css i have used the recode method with no problems at all as nero recode removes all the css and makes it playable on the htq systems im hoping that they will do a firmware update that may fix this annoying problem but until then the way i have used will help for the mean time.
or
you can also try using dvdshrink that seems to have worked from what i have seen.
Also dvd decrypter and use the region free and remove puos (from the tools section) seems to have worked for me this morning.
hope this helps you these methods are working fine for me on my ht-q 20
hi buyu,
thanks for your advice, after recoding with nero the player accepted all dvds!
i hope that they update the firmware, if you have an firmware update it would be nice if you will remember me and my problem!
thanks and greetings to london!
your very welcome and yes when i find a decent firmware i will let you know asap
all the best to germany
hi all i am new here and have just bought the same home theatre system
the chap in the shop gave me all the normal speel yeah m8 it plays erm all no worries GRRRRRRRR still can't deide weaher to take it back or not
sad thing is i like the look of it
if there is a firmaware update plse let us know m8
actually there is a firmware update, once done, everything is sorted out, it plays any type of dvd's and the sound is more crisper
http://www.samsung.com/in/support/do...ia_cd=03031700
no ive got same problem will not play any dvd's not even original , you can get 1 or 2 to work now and again if you keep opening and closing , or turning off and on a good few times.
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 09:34 -
Firmware for Samsung HT-Q20 trouble
By geminni in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Jan 2009, 07:34 -
HT-Q20 to play CD-G
By mark6804 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 24th Oct 2008, 00:22 -
Samsung HT-Q20
By penguarea12 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jul 2008, 15:05 -
Samsung ht q-100 can't play backup DVD's???
By infoman99 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th Oct 2007, 12:09
