VideoHelp.com Forum
    My original movie has 4 audio streams. I removed the 2nd stream and when i
    reauthored the movie all audio streams, except the 1st one, had moved one place up,
    so that the 3nd stream of the original dvd took the 2nd place in the reauthored
    and the 4th stream took the 3rd place. After that, anyone can understand what happened
    to the audio selection of the reauthored dvd.
    I have worked this out with IfoEdit, but not with PgcEdit.
    I would appreciate it very much if someone could tell me a way to add an audio stream between the 1st and the 2nd streams, with PgcEdit.
    Thanks.
    diamath,
    Correct me if I'm wrong, but it doesn't sound so much like you want to physically add an audio stream as just re-arrange the stream assignments.
    If that's the case, double click on the TTN for the movie (if that's what you want to change), and when the PgcEditor window comes up, in the frame on the top (titled "Audio Streams") is where you can change the audio stream assignments. Click on a stream to bring up a little window that has a slider bar, a button to disable the stream, a button to set the stream to the value on the slider bar, and a Cancel button.
    If I'm understanding correctly, note the values on the top 3 buttons. Set the value for the 4th button in the list to the current value of the 3rd button. Set the value for the 3rd button to the current value of the 2nd button, and set the 2nd button to disabled (none).
    If I've misunderstood, don't hesitate to let me know.
    As always, it's a good idea to save a backup of the original, just in case.
  1. Replies: 2
    Last Post: 25th Mar 2010, 00:46
  2. avidemux audio shift problem
    By allenn in forum Video Conversion
    Last Post: 16th Dec 2009, 21:44
  3. Audio shift problem in Avidemux
    By sir_ken in forum DVD Ripping
    Last Post: 18th Sep 2009, 12:25
  4. Two Different Audio Streams In The same VTS.
    By GangstaRap in forum Authoring (DVD)
    Last Post: 22nd Jan 2009, 10:00
  5. Video with 2 Audio Streams TO mpeg1 with 1 audio stream
    By Xenogear900 in forum Newbie / General discussions
    Last Post: 5th Aug 2007, 19:00
