I'm having a problem with converting a .mov file exported from iMovie 6 to an Xvid .avi file using the latest version of ffmpegX 0.0.9w
The only solution I've found is to export using "Movie to DV stream", which generates huge source files but it's the only way I've found.
This doesn't happen with all files exported from iMovie. In this case, the problem file is using only JPEGs inserted into the timeline and a few titles, along with a single music track.
Checking the "Invert mapping" check box in the Audio tab of ffmpegX 0.0.9w does not fix my problem.
The prime suspect for me are the plugins installed into QuickTime. I'm running the Flip WMV and DivX plugins with QT 7.3.1, and I figure one of them may be interfering with ffmpegX decoding of the audio in my iMovie-output .mp4 (Full Quality) file...?
It's a guess at this point, and re-installing QuickTime 7.1.3 doesn't appear to fix the problem either.
After removing WMV and other QuickTime plugins, reinstalled QT 7.1.3.
Much to my dismay, I still get no audio track in iMovie 6.0.3 exported (Full Quality) files converted to MPEG-4 .avi file using ffpmegX.
Results 1 to 1 of 1
Importing h.264 mp4 files into After Effects bug?
By Flynn in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2012, 09:17 -
.avi file playback bug
By uruquiora in forum DVB / HDTVReplies: 1Last Post: 14th Oct 2011, 12:32 -
BD_Rebuilder Bug or File missing
By Raul124 in forum Blu-ray RippingReplies: 1Last Post: 18th Nov 2009, 02:01 -
MPEG-2 video/audio to MP4 or anything iMovie will import
By quella in forum MacReplies: 9Last Post: 3rd Dec 2007, 19:07 -
cut Video file by iMovie/iDVD
By cebep in forum MacReplies: 1Last Post: 2nd Dec 2007, 07:19
