Ok, here's the story:
I recently downloaded a .mkv file from BitTorrent. It has .h264 video, .ac3 audio, and VobSub subtitles (.idx if I recall correctly.) I can watch the video just fine in WMP.
However, when I extract the streams to convert it to a DivX movie, I run into problems. I can't play the video file (.h264 format) in ANY player, even though I recently installed the codec. I'm trying to use ImTOO MPEG Encoder to convert it into something VirtualDubMod can handle, but that doesn't seem to work either. I can preview the .h264 file in ImTOO, but it claimsto have a length of 0:00:00 and a bitrate of 0. I inevitably get an error while trying to convert it. Since VDubMod doesn't like .h264 video or .idx subs, I'm using MKVExtract to extract the streams (it's available on the matroska website, along with a convinient GUI for it.) I know it's not a problem with that program because I used it earlier to extract the streams from some other .mkv files and the only problem was a slight loss of quality.
I'm at a loss for what to do. Any help at all will be appreciated. I'm not posting the torrent file here, but I can provide it on request if you want to look at the files yourself.
EDIT: On second thought, I'm not going to provide the torrent. Good ting I reviewed the rules![]()
Not a lot of apps handle raw AVC streams well. Better to just leave it as an mkv and convert that.
Also mkvextract does not cause any quality loss. All it does is extract streams. For native AVC streams it extracts to raw AVC. For streams using VfW compatibility it extracts to avi which is probably what happened with the other mkv files.
If you really want to you can use avc2avi to remux the raw stream to avi. Will still be AVC though, not DivX.
I'm not sure how to directly convert .mkv to .avi, especially with multiple audio streams. However, I think ImTOO handles raw AVC video. I'll try renaming the file to .avc and see what happens.
I'll also try and find avc2avi and see how that goes. Thanks.
Correct extension is I believe *.264.
Yeah from recollection ImToo is ffmpeg based which means it can handle raw AVC streams. Could end up with 25fps as default though. Should also support mkv input anyway since libavformat can also handle that..
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 14:13 -
How to play avi/H264 video file on WMP 12
By Tatl in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2010, 18:02 -
MKVextractGUI: extracted video result in .h264 format instead of .mp4
By shichi00 in forum Video ConversionReplies: 1Last Post: 19th Mar 2010, 03:28 -
No sound from matroska file with h264 audio.
By anarchyx34 in forum ffmpegX general discussionReplies: 3Last Post: 29th Oct 2009, 14:33 -
What do I do with a raw .h264 file extracted from an .mp4 container?
By godfist314 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2008, 12:51
Statistics
Newest guides
Latest tool updates
New media comments
