Hi Folks:
Used *.v for a long time. Upgraded to *.x_r2 (with new binaries) and suddenly the output stops with two files (video and audio) but doesn't put them together.
I teach video, so I extract VOBs and convert them to MP4 for easy display to my students. Previously, I could drop a VOB on the Source Format box, change Target Format box to "h264.mencoder" and that was it. Occasionally, a VOB wouldn't work, so I'd first ffmpegx it to MP4 directly, and then convert the latter to MP4(264).
Now I get two files (*.mp4.mov.264 and *.mp4.mov.aac.mp4) and the application quits without any error notification.
Perplexing thing is that I can go VOB=>DivX mencoder without any problem.
Have included a "Terminal" session below. Any suggestions would be most appreciated. (There is a "1212 Bus Error" near the bottom, but I have no idea what that is or if it is affecting anything. My setup today is identical to yesterday's when the *.v version was working.)
Thank you very much for your time.
Best regards,
Michael-john Morgan
Last login: Tue Oct 24 11:44:57 on ttyp1
Welcome to Darwin!
g5HD:~ g5HD$ /Applications/ffmpegX.app//Contents/Resources/pbpaste | sh
Encoding started on Tue Oct 24 11:44:58 PDT 2006
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x367f800
MPEG-PS file format detected.
VIDEO: MPEG2 720x480 (aspect 2) 29.970 fps 7700.0 kbps (962.5 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
Opening video filter: [pp=0x33]
Opening video filter: [harddup]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred colorspace: Mpeg PES)
[PP] Using external postprocessing filter, max q = 6.
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
Also try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
x264 [info]: using SAR=11/15
x264 [info]: using cpu capabilities Altivec
Writing AVI header... 0%) 0.00fps Trem: 0min 0mb A-V:0.000 [0:0]
1 duplicate frame(s)!
Pos: 70.9s 2126f (99%) 24.05fps Trem: 0min 6mb A-V:0.000 [794:0]
Flushing video frames
Writing AVI index...
Fixing AVI header...
Video stream: 794.556 kbit/s (99319 B/s) size: 7042171 bytes 70.904 secs 2126 frames
x264 [info]: slice I:20 Avg QP:22.85 size: 19754
x264 [info]: slice P:2105 Avg QP:25.30 size: 3152
x264 [info]: mb I I16..4: 49.5% 0.0% 50.5%
x264 [info]: mb P I16..4: 5.9% 0.0% 0.3% P16..4: 29.0% 12.8% 3.0% 0.0% 0.0% skip:49.0%
x264 [info]: final ratefactor: 23.03
x264 [info]: kb/s:793.2
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
built on Dec 1 2005 03:50:24, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, h264, from '/Users/g5HD/Desktop/BSMA/Modern Times #03 Title 1 (Ch1 - Ch20)/VIDEO_TS/Chapter 1.VOB.ff.264':
Duration: N/A, bitrate: N/A
Stream #0.0, 29.97 fps: Video: h264, yuv420p, 640x352
Input #1, mpeg, from '/Users/g5HD/Desktop/BSMA/Modern Times #03 Title 1 (Ch1 - Ch20)/VIDEO_TS/Chapter 1.VOB':
Duration: 00:01:10.5, start: 0.060000, bitrate: 6481 kb/s
Stream #1.0[0x1e0], 29.97 fps: Video: mpeg2video, yuv420p, 720x480, 7700 kb/s
Stream #1.1[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #1.2[0x81]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #1.3[0x80]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Output #0, mp4, to '/Users/g5HD/Desktop/BSMA/Modern Times #03 Title 1 (Ch1 - Ch20)/VIDEO_TS/Chapter 1.VOB.ff.aac.mp4':
Stream #0.0: Audio: aac, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #1.1 -> #0.0 [sync #0.0]
Press [q] to stop encoding
size= 1049kB time=70.9 bitrate= 121.3kbits/s
video:0kB audio:1023kB global headers:0kB muxing overhead 2.599040%
sh: line 1: 1212 Bus error /Applications/ffmpegX.app//Contents/Resources/mp4box -fps 29.97 -add /Users/g5HD/Desktop/BSMA/Modern\ Times\ \#03\ Title\ 1\ \(Ch1\ -\ Ch20\)/VIDEO_TS/Chapter\ 1.VOB.ff.264 -add /Users/g5HD/Desktop/BSMA/Modern\ Times\ \#03\ Title\ 1\ \(Ch1\ -\ Ch20\)/VIDEO_TS/Chapter\ 1.VOB.ff.aac.mp4 -new /Users/g5HD/Desktop/BSMA/Modern\ Times\ \#03\ Title\ 1\ \(Ch1\ -\ Ch20\)/VIDEO_TS/Chapter\ 1.VOB.ff.mp4
g5HD:~ g5HD$
Results 1 to 1 of 1
Combining MP4 files (h264) with mencoder results in blank (white) videos
By mstaker in forum Video ConversionReplies: 0Last Post: 10th Dec 2011, 14:35 -
HELP! This is all new for me. Edit 2 separate minidv audio/video files.
By nexgraphics in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2009, 09:45 -
Extracting/demuxing a .TS into separate video and audio files?
By mkvbob in forum DVB / HDTVReplies: 10Last Post: 25th Jul 2008, 02:15 -
converting format using separate video and audio files
By joshua4 in forum Video ConversionReplies: 4Last Post: 11th Jun 2008, 03:09 -
All of a sudden separate audio & video files
By amigasteve in forum ffmpegX general discussionReplies: 6Last Post: 16th Dec 2007, 16:59
