VideoHelp.com Forum
Results 1 to 9 of 9
    Can anyone please point me in the right direction. I am interested in making a funny silent home movie for the holidays for my family with existing camcorder footage. I am looking for a windows based program that will allow me to mimic the old style silent movies by doing the following: speeding up the film, adding aging effects to it, changing color to black and white, and if possible adding the ability to insert the old style full screen caption dialogue boxes.
    Any help wopuld be greatly appreciated. I know there are many great minds in this forum. Thanks
    jj
  2. Member steveryan's Avatar
    For starters try the old cinema filter for Virtualdub, it's very good. http://www.compression.ru/video/public_filters.htm
    He's a liar and a murderer, and I say that with all due respect.
    First to come to mind that can do all that easily is Ulead VideoStudio v10. Not free but trialware for 20-30 days I think. Aging by using the old film filter, speed by using framerate adjustment, silent by muting the existing audio track, movie by adding your soundtrack(s), insert caption dialogue by adding custom titles. Easy.
    Good luck.
    EditStudio has a great "old film" effect built in and you can adjust all of the settings.
    The full-screen titles would be easy. Do a layer underneath that has a black background and the old-style frame, put the movie above it with the old-style effect applied directly to it, "Split" the movie at that points where you want text and put the text into the hole.
    For each piece of the movie you can adjust the speed with a slider, enter a percentage, or use a tool to stretch or contract the scene.
    The support on their forum is wonderful with the developers always checking in.
  5. Always Watching guns1inger's Avatar
    virtualdub can do all of this, although adding the captions would be a little tricky
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Thanks all for such a quick response!!!! I will get to work immediately and try all these wonderful suggestions. Ill post periodically as to my progress.
    Thanks again!! jj
    I would do it in Adobe Premiere. I've done this before, just playing around.
  8. quicktime pro also has an "aged film" effect. Try blurring your video a little, too.
  9. Member daamon's Avatar
    I second both of these, but that's coz I've already got Premiere - it could be a bit expensive otherwise.
    I'd be inclined to "treat" the raw footage to aging in VirtualDub with the "old cinema filter" and then use the resultant DV AVI for editing in Premiere or similar. But there's more than one way to skin a cat...
    Good luck.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  1. Possible to encrypt your home movies??
    By slaak in forum Newbie / General discussions
    Last Post: 21st Jan 2010, 11:06
  2. Replies: 13
    Last Post: 16th Oct 2009, 12:28
  3. Old Home Movies
    By pokereyes101 in forum Newbie / General discussions
    Last Post: 20th May 2009, 20:05
  4. Trying to create a process for creating home movies reliably and need help
    By Arphahat in forum Newbie / General discussions
    Last Post: 16th Feb 2009, 11:19
  5. Burn Home movies
    By Tailgunner9 in forum Authoring (DVD)
    Last Post: 3rd Nov 2007, 12:26
