Results 1 to 13 of 13
  1. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    You see I have this movie which is 1,36 GB but the thing is it has a only 2 channel sound...Not so good resolution 640x464 and yet it is 1,36 GB? It should of had atleast a 5.1 channel sound. So anyway i need to make it fit into a normal 700MB cd what should i do to change the file size? When I try to load it to virtual dub and save it ... it turns like 400 mb and get even worse resolution... Any ideas how to make the movie 700mb?
    AutoGK and set the output size to 700MB but it the video quality will get worse. It's best to reencode from a better source like DVD:
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Use AutoGK, and set output size to 700 MB. But, quality will suffer.
    <edit>Ah, great minds think alike! </edit>
    /Mats
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Save yourself a lot of time and split to 2 discs using Virtualdub.
    He's a liar and a murderer, and I say that with all due respect.
  5. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    The desire to cram everything to the size of a single CD-R is often a very bad desire.
    Do as steveryan says ... won't take long and the quality will not suffer.
    CD-R discs cost what these days? ... 25 cents or so?
    - John "FulciLives" Coleman
    Nov 2002
    Guess it costs a lot more in Eastern Europe.
  7. Member FulciLives's Avatar
    May 2003
    LOL
  8. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    No thing is that i just dont see the point of that movie being on 2 Cd's and with just a 2 channel sound. When most of movies on 2 CD's are 5.1 channel sound and better resolution. Only movies on 1CD are with 2CH So I that's why im resizing it. I doubt it would get worse than this...
  9. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    kschang ur right they are more expensive 35 cents. And I have like 50 of them and 50 dvd's. It's not the problem that i don't have CD's It is something which I have a lot to explain and dont feel like doing it.
    Dec 2004
    Australia
    Better to burn on 1 DVD than 2 CD's anyway. Only one disc and 1 DVDR should be cheaper than 2 CDR's.
    Dec 2003
    You didn't say but if that movie is 2 hours long and it is has 192K audio, then the bitrate is somewhere around 1381Kbps. If you were to reencode to 690MB (1 cd) then the bitrate looks like 600Kbps. I've did a few 600Kbps Divx 2 pass encodes before that looked ok I guess.
    I too think you will take a quality hit if the original is already mpep4. lol
    Good luck.
  12. Member JConnor's Avatar
    Apr 2006
    Bulgaria
    Well i reencoded it to 700MB...Don't see a big difference to be honest.
    Dec 2003
