VideoHelp.com Forum
    I have a GUI called SUPER. This GUI is able to change my .flv to a .avi fine but I need the command line.
    the GUI provides this info:
    Use Video codec: H.264/AVC, Maintain input's scale size & aspect ratio, 1008 kbps, 25 fps
    Use Audio codec: mp3, Stereo, 96 kbps, 22050 KHz, AudioStream [default] is selected
    When I tried this command line it converted the audio but not the video:
    ffmpeg -i "C:\movie.flv" "C:\movie.avi"
    If any knows the correct command line please post
  2. Member Krispy Kritter's Avatar
    The command line options are listed on the software home page.
    Google is your Friend
    be sure to use a new build of ffmpeg also, http://ffdshow.faireal.net/mirror/ffmpeg/
    I'm sorry but I don't know which command line options to use.
    I've tried a lot of different things but none seemed to work.
    I think I just need it the video codec (whatever that is) to be H.264/AVC, and the audio codec to be mp3.
    I tried to do this:
    ffmpeg -i c:\movie.flv -vcodec h264 -acodec mp3 movie.avi
    but it says unsupported codec for output stream #0.0
    I really have no idea what I am doing (if you haven guessed that already).
    any help would be appreciated.
    GM6CM
  5. Member Krispy Kritter's Avatar
    How about a guide from the HOW TO - CONVERT section to the left<<<<<<<<<<<<<<
    http://www.videohelp.com/guides.php?...or+List+Guides
  1. Replies: 9
    Last Post: 6th Oct 2011, 21:21
  2. Tool or command line to batch remux x264 acc .mp4 in .flv
    By Gargalash in forum Video Conversion
    Last Post: 25th Aug 2010, 07:29
  3. Command-line command for fixing AVI?
    By timur in forum ffmpegX general discussion
    Last Post: 23rd Sep 2009, 02:23
  4. Mencoder 2-pass Command Line to flv
    By mrready in forum Video Conversion
    Last Post: 16th Dec 2007, 03:25
  5. Mencoder 2-pass Command Line to flv
    By mrready in forum ffmpegX general discussion
    Last Post: 15th Dec 2007, 11:49
