I already search alot of software that can convert RMVB video file to AVI file, but i failed,
one of the software that i had tried is mediacodec, but i must convert sepret the video file and audio file and it takes me 1 hours ++ to finished the converting
are there any software that can convert the RMVB file without sepret them?
and arae there any software that can extract out the subtitle from the RMVB file?
thanks for the help
Does RMVB has sperate sub streams, or is it encoded int he video ? If it is encoded int he video then you can only use delogo tools, which tend to not do very good jobs with subtitles. You are better off masking it out, or living with it.
Extract Subtitle Stream from MPG (Used VOB2MPG to create file)
By secretsubscriber in forum SubtitleReplies: 2Last Post: 4th Jun 2009, 14:02 -
extract subtitle from mkv file
By py52126 in forum SubtitleReplies: 1Last Post: 4th Feb 2009, 17:01 -
Extract audio and edit from RMVB
By sychern in forum Video ConversionReplies: 1Last Post: 16th Oct 2008, 03:45 -
Extract Subtitle embled in AVI file,VirtualDubMod n GraphEdit didn't work..
By quang010692 in forum SubtitleReplies: 1Last Post: 5th Oct 2008, 02:44 -
How to extract subtitle stream in .divx file and save as idx/sub
By newnews in forum SubtitleReplies: 1Last Post: 29th Jul 2008, 13:36
Statistics
Newest guides
Latest tool updates
New media comments
