others are having no trouble playing it though.
Its the same files.
I downloaded something in mdf/mds format and extracted with magic ISO. now tried to play the file with windows media player, classic media player/real alternative, vlc player, xvid and windvd.
This is what I get:
audio is high pitched, squeking and video shows GREEN boxes and i can't see the proper video at all. just these green boxes moving around.![]()
So you're going to say its corrupt. but then how come others can play it find though??
also, i tried using g-spot (g-spot doesn't really support dat file though) and didn't come up with any errors (it just showed me info, it didn't scan the file. as i said, it doesn't support it).
Any experts out there wanna help a video-dumbo here?![]()
How do you know others can play it without any problems? Are they playing copies that you gave them?
Chances are, the file is corrupt or you don't have the proper codecs installed.
Use a tool such as ISOBuster which can extract the mpg file from your image.Google is your Friend
the reason i know others have no problem is because they reply to the thread where i downloaded the file and no one said anything about having problems.
ill try iso buster out.
thanks.
WORKS NOW!! also so much frustration.
i conclude that the trial magic iso and power iso sucks.
Thanks, ill be using buster from now on
how to seperate audio from DAT file
By pcb in forum AudioReplies: 5Last Post: 4th Jul 2011, 14:51 -
PC Doesn't Restart Properly
By bevills1 in forum ComputerReplies: 5Last Post: 5th Sep 2010, 21:20 -
Why my PC cannot play HD video properly?
By kouras in forum DVB / HDTVReplies: 5Last Post: 19th Dec 2008, 08:25 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
AVSEQ.DAT file -video cd can't copy and play
By desiboy1436 in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th Jul 2008, 10:43
Statistics
Newest guides
Latest tool updates
New media comments
