My NEC 1300A (firmware 1.0A) has been very well to me until recently when it keeps giving me burn errors.
my computer does seem to be running slower than usual so I don't know if that may hae to do with it. Here is my error log:
7:22:01 PM #1 Text 0 File Isodoc.cpp, Line 6013
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
7:22:01 PM #2 Text 0 File Reader.cpp, Line 118
Reader running
7:22:01 PM #3 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-1300A running
7:22:01 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
7:22:01 PM #5 Text 0 File Burncd.cpp, Line 3218
Turn on Disc-at-once, using DVD media
7:22:01 PM #6 Text 0 File DlgWaitCD.cpp, Line 233
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2173973 (483:06.23)
7:22:01 PM #7 Text 0 File DlgWaitCD.cpp, Line 238
Write in overburning mode: FALSE
7:22:01 PM #8 Text 0 File DlgWaitCD.cpp, Line 1997
Recorder: _NEC DVD_RW ND-1300A, Media type: DVD+R
7:22:01 PM #9 Text 0 File DlgWaitCD.cpp, Line 398
>>> Protocol of DlgWaitCD activities: <<<
7:22:01 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 773
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2173824 (2173824) = #2173824/483:4.24
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2173824 blocks [_NEC DVD_RW ND-1300A ]
7:22:01 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 942
Prepare recorder [_NEC DVD_RW ND-1300A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4451991552, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2173824 | lead-out | 1 | 0x00 | 0x41
7:22:01 PM #12 Phase 24 File dlgbrnst.cpp, Line 1803
Caching of files started
7:22:01 PM #13 Phase 25 File dlgbrnst.cpp, Line 1803
Caching of files completed
7:22:01 PM #14 Phase 36 File dlgbrnst.cpp, Line 1803
Burn process started at 4x (5,520 KB/s)
7:22:01 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2146
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:22:01 PM #16 SCSI -1066 File Cdrdrv.cpp, Line 1167
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02C85000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
7:22:01 PM #17 Text 0 File dlgbrnst.cpp, Line 1661
Set remaining time: 13:37,129 (817129ms) -> OK
7:22:01 PM #18 Text 0 File DVDPlusRW.cpp, Line 566
Start write address at LBA 0
DVD high compatibility mode: Yes
7:29:19 PM #19 SCSI -1093 File Cdrdrv.cpp, Line 1427
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02F30000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x03 0xAC 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x02 0x00
7:29:19 PM #20 CDR -1093 File Writer.cpp, Line 301
No seek complete
7:29:19 PM #21 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
7:29:20 PM #22 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
7:29:20 PM #23 SCSI -1135 File Cdrdrv.cpp, Line 1167
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x0C 0x00
7:29:20 PM #24 SCSI -1176 File Cdrdrv.cpp, Line 1167
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x03
7:29:20 PM #25 Phase 127 File dlgbrnst.cpp, Line 1803
Generating DVD high compatibility borders
7:29:20 PM #26 Text 0 File dlgbrnst.cpp, Line 1661
Set remaining time: 0:00,000 (0ms) -> OK
7:29:20 PM #27 CDR -1135 File WriterStatus.cpp, Line 162
Write error
_NEC DVD_RW ND-1300A\H1 T1
7:29:20 PM #28 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
7:29:20 PM #29 Text 0 File dlgbrnst.cpp, Line 1661
7:29:20 PM #30 Phase 38 File dlgbrnst.cpp, Line 1803
Burn process failed at 4x (5,520 KB/s)
please help! I may just retire this and get a newet DL burner if necessary, but i'd prefer not yet if it's salvagable.
Thanks!
Results 1 to 30 of 77
Thread: NEC 1300A DVD Burner Errors
The NEC ND-1300A was my first DVD burner.
That was a LONG time ago.
So it wouldn't surprise me that it is finally giving you issues ... it's old!
As for mine ... I got a new computer with a newer DVD burner that was faster with DL capability so I stopped using my NEC ND-1300A long before I had issues with it.
But my point is ... that model is so old now ... no wonder it isn't working anymore.
Time I think for something new.
At least a new DVD burner can be had for around $50 or so ... I think I paid around $200 for my NEC DN-1300A when I first got it plus a blank DVD-R was around $3.50 at the time.
Yea, it is pretty old, (I paid $100 for it back in the day) so maybe it is just finally showing its life. My computer has been slower than usual lately though, so if it's a hard drive or other hardware issue, I don't want to spend the money on a new dvd burner if it won't fix it.
I do like my NEC tho, so for a new one, would you suggest one of the newer NECs as well or another brand?
THanks!
As inexpensive as DVD writers are these days (<$50), having to buy another one isn't so bad.
I use an NEC ND-3450A with great results. Before that an NEC ND-2500A (still in service). It's good to have a couple just in case something like your situation happens.
I'm not "up" on current DVD burner models but generally speaking you can't go wrong with Pioneer or NEC models.
- John "FulciLives" Coleman
P.S.
Now that I think about it maybe my NEC ND-1300A was $100 and not $200 but that was SO long ago I forget now LOL but I do remember that 10 packs of 2x DVD-R discs (Maxell and Fuji) were $34.99 in retail stores. Of course they came in full sized CD style jewel cases but still that was a lot of money per disc."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
so based on the age of my burner and the error code, you guys think it's the burner and not anything else? I just dont want to install the new burner and still be having the same issues.
this didn't happen till just recently, when my computer started acting up, i did a system restore and all seemed fine, then undid my restore cause of some program activation issues, and then just last night started having issues. It gave me errors, after a restart it burned about 3 dvds fine, and now is giving issues again.
on the computer front, programs seems to be lagging a lot, and will temporarily not respond if i try to switch to another program, again a recent problem. So if its another hardware issue besides the burner, dont want to bury my trust nec1300a just yet, at least not until a good deal on a new burner shows up.
My point about having two burners. If the problem persists on the new burner then that's an indication that it's not the old burner but something with the system. If the new burner works fine, that's an indication that the old burner may be the problem. No it's not the cheapest way to diagnose the problem, but it may be the quickest.
Plus you could always buy a DVD burner at a retail store ... thus you can easily return it if it is also giving you problems ... which would indicate that the issue is not the NEC but something else.Originally Posted by bobkart
I once bought a capture card from Circuit City to try it out even though it was nearly 50% more than mail-order. When I found out I liked it I returned it to Circuit City and ordered it on-line. heh.
I may just buckle down and get a new burner, since this one is a 4x and speeds are higher these days. But like i said, don't want to waste money on a new one if it's just going to give me the same errors.
just did a DVD and finally it worked, after 2 failed ones tonight. It's all very odd. Had to restart my computer a couple times, and then only when the computer seems to be working okay does the DVD burner work well.
One thing I noticed was on the failed time my "used read buffer" would never quite reach up to full level and my other buffer bar would move like crazy from 100 to 10s and back. On a good burn, the "used read buffer" got full then proceeded to burn and the other buffer bar's percentage didn't seem to change. Both times my computer environments have been the same, so I dont know if its the burner acting up or my computer is running things in the background that i don't know about...
hmm i hadn't thought of that, that may be an idea! yea, i never buy hardware from stores, unless it's a really good deal.Originally Posted by FulciLives
It couldn't hurt (free) to give your system a little tuneup.Originally Posted by Angela627
Download crap cleaner: http://www.filehippo.com/download_ccleaner/
A registry cleaner Eusing: http://www.eusing.com/
Another registry cleaner Regseeker: http://www.hoverdesk.net/freeware.htm
Then get out the hard drive defragger (windows xp one does ok)
Flash to the latests firmware here:
http://cdrinfo.com/Sections/Firmware...px?DriveId=745
http://forum.rpc1.org/dl_firmware.ph...&manufactor=23
If all else fails you can keep the 1300a as a dvd/cd reader.
You may want to verify your hard disk and DVD-RW are in DMA mode also...seems to be a common occurance for them to be in PIO mode.
Personally, I tend to suspect hardware last. There are simply too many other factors involved, worth investigating first. Other media? Other burner app? Latest firmware?
Still have my old 1300A as my first (and so far only) DVD burner. After my initial noob mistakes, it has so far never failed me.
/Mats
Thanks for the suggestions, I will try to do the system tuneup tonight when I get home. I couldn't hurt my system anymore (hopefully).
I hadn't realized Herrie released a 1.0C, so definitely will update the firmware too.
as far as media, im on a spindle that has been fine the last 30 burns, so odd that it just decides it doesn't like them anymore. They're also riteks which I have never had issues with before. And I have a separate DVD-ROM that I use as a reader, I don't like using my writer as a reader.
one thing my computer started doing is telling me there is no disc in my E drive (DVD-Rom) and it can't read the file, yet I never inserted a dvd in or was trying to access it. It just starts doing it on it's own then gives me the error. Don't know if that has to do with the issues i'm having as well...
how do i do that?You may want to verify your hard disk and DVD-RW are in DMA mode also...seems to be a common occurance for them to be in PIO mode.
Thanks for the help!
used a 1300A for 2-3 years before it stopped burning DVDRs. It would still burn CDRs and read CD(R)s and DVD(R)s. It was a great burner.
Got a 3540 to replace the 1300A. Best $39 spent! and that was about 8 months ago.
okay, well i did the registry clean up, defragged the hard drive, updated the firmware. And still getting errors.
I thought id give it a shot with a dvdrw this time so i wouldn't waste another dvdr. the used read buffer jumped out to 100% then a minute later or so it just kept falling down. then i browsed a webpage and my nero just stopped responding. Which hasn't happened in a long time, I also have 1 gig of ram in my system, so really it should be able to handle 2 programs at once.
Earlier my computer did seem to lock up for a good minute, freezing up when i tried to change between a program, which it never had issues with before. And again, 1 gig of ram is plenty. So at this point I dont know if its a hardware of the writer or a hardware of something else???
Did you change the RAM recently? Having bad RAM can cause all kinds of system problems but my understanding is that RAM can be bad when new but doesn't really "go bad" so if you haven't changed RAM recently then forget this suggestion.
When burning you should not do anything else.
Also you should never use NERO for DVD burning ... at least not DVD Video burning ... but that's another story.
Nope, RAM has been unchanged. When i first installed it my computer had some issues, i thought it might have been a RAM issue, but when my hard drive started sounding like a ticking time bomb I changed it out and everything was smooth and running fast, until now...
I usually dont do anything else when burning, but I never had issues before, so since i was trying to test out the drive, I just replying to an email and nero didn't seem to like that.
so if not nero, what do you suggest. I was actually burning a data dvd, not a video dvd. But at this point im up to trying a different software before giving up all together.
running a checkdisc on the pc right now...its taking a long time verifying file data...
I have no idea what to use for a Data DVD other than NERO but for DVD Video burning the best application is ImgBurn and not that long ago ImgBurn got a major update (it worked fine for ages but now has more functions) so maybe it can do a Data DVD now ... not sure. I rarely make Data DVD discs so ...
It really sounds like your computer has some major issue though so the only advice I can give ... not a popular option ... but sure to "work" ... is to back up your data (an external USB/FIREWIRE HDD is a good choice) and re-format the HDD and re-install Windows fresh.
Sometimes Windows just gets "messed up" and even fixes like registry clean software etc. can't fix it.
So sometimes a fresh Windows install on an empty erased/re-formated HDD is the only "trick" to make it work again.
sigh, i may have to do just that, cause now upon finishing up the diskcheck my computer has told me my wsftp no longer works, and ive done nothing to it and also just used it this weekend.
and now my current burn is stuck at 34%, the remaining time has been at 0 for over 5 mins and total time keeps moving up, but nothing else is moving.
sigh, just seems like more problems arise.
even before when I had major hard drive issues and my computer was running slow as ever, my dvdburner still never crapped out so I could still back up files to my dvds before formatting, now I dont even have that option. Well looks like its time to get an external hard drive, any recommendations? Im not even sure if my computer has USB 2.0s...
Well these days you can buy an external HDD that is ready-to-go i.e., already in an external enclosure that is either USB 2.0 and/or FIREWIRE compatable. Should (knock on wood) also work with USB 1.0 but my guess is your computer has USB 2.0 if it is a P4 2.4Ghz just based on what was "popular" then in terms of USB when that speed processor came out.
Another option ... you can buy an external case and put an existing HDD in it. I have two myself like this that I bought at CompUSA for something like $40 and work with USB. If you have an existing HDD to use this would be a cheaper solution than buying a new external HDD.
However it sounds that your computer is so f'ed up that you might have trouble trying to copy stuff to an external HDD.
In which case you might have to take out the current HDD and back it up using another computer ... or take it out and replace it with another HDD and reformat with that then extract the data from the "old" HDD once the system is stable.
well i have 2 hard drives in my system. I have one hard drive that i run my OS off of and keep some files on but the bulk of my files are stored on another hard drive just cause unfortunately formating and restalling OS seems to be a norm with windows and at least I can keep my files this way. It's just the hassle of having to install all my programs over again that I hate. But it seems like I really have no choice in the matter here. So i'll just have to put in that seagate that ive had waiting on my shelve, and then if my burner still won't work, then I guess its time to upgrade to a faster burner, and enter the realm of DLs.
okay well now im trying to backup some files from my C drive to a DVDRW and it seems to be going fine... yea im really confused by my computer and burner right now.
I've had a DL capable burner since December 2004 and I've yet to burn a DL DVD disc LOL
I do hope the install trick works for you ... sucks when a computer doesnt' work as it should.
I feel your pain!
DL discs are still too expensive, it's the reason why I haven't felt the need to upgrade to a faster DL burner. Because really the 4x 15min doesn't botter me all that much cause I usually just leave my computer when Im burning.
and now...it seems to be burning fine on my DVDRW. I don't get it!!! Either just work or dont work at all, stop toying with me!
Reminds me of a vibrating adult toy I had once ... it had a "bad" connector inside and you would have to shake it sometimes so the batteries would "connect" and it would purrr it's magic.Originally Posted by Angela627
It would pick the worse times to stop working too.
LOL, tmi dude
CD Burner XP Pro. Doesn't do Video DVD tho.Originally Posted by FulciLives
/Mats
okay so my dvdrw i used to backup files from my C drive burned fine. thought i'd give it another go with my original project, it actually didn't fail this time, but instead took nearly 40 mins to burn when i usually burn at 4x in about 15 mins.
Interesting enough the dvd that burned normally was from files that were on my C drive, the one that took 40 mins (or usually failed) is from files being pulled from my D drive, and it is also making my computer lag in the process (which wasn't happening during the successful burn). Thinking at this point it may have something to do with my D drive, yet I don't keep any exe files on it or run anything off of it, only used for storage so that's odd to me...
Looking at some other threads, it might be the DMA/PIO thing?
You should have the two HDD's on one IDE cable and the Burner (along with a DVD reader) on the other IDE cable.Originally Posted by Angela627
Never mix a HDD with an optical drive when it comes to the IDE cable.
That's one thought.
Another thought is that D drive is slipping into PIO mode instead of DMA mode or worse yet it is just dying on you.
Yea that is how my computer is set up. the 2 HDDs are connected on one cable (master/slave) and the 2 dvd drives are on another cable (dvd-rom being master, writer being slave).
Could the hard drives have just slipped into PIO mode by itself suddenly? Cause everything was working fine on my computer until I tried to extract a winrar file on night, then that's when all the problems started happening. My friend had the same winrar and had no issues with her computer tho. How can I try to fix it via DMA? giving it some last attemps before the last resort of formating/exchanging out hdd.
2 ways I check DMA status:
Right click My Computer>Hardware tab>Ide Controllers>Primary/Secondary>Advanced Settings
Nero Tool Kit> Infotools>Configuration
Don't trust the Device Tree by itself, compare it to Nero Infotools. I've seen it where the Device Tree says DMA mode on but Nero infotools and Nero burn log showed DMA off. Try to avoid using any IDE drivers that come with the motherboard and stick with the generic Microsoft drivers for highest compatibility and fewer problems.
Errors burning movie to BD-R using HP bd340i burner & PowerProducer softwar
By BDNov in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Feb 2011, 08:34 -
Explanation for Samsung Burner Errors
By Seeker47 in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Jul 2009, 11:16 -
Errors playing Blu-Ray films on LG Burner,
By havash in forum Software PlayingReplies: 7Last Post: 20th May 2009, 23:00 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 06:16 -
I/O errors with my new Pioneer DVR-115D burner
By gshelley61 in forum ComputerReplies: 4Last Post: 12th Jul 2008, 14:25
