VideoHelp.com Forum
    Hello,
    This is my first posting, so please be gentle with me!
    I am not sure which forum this question should be on either, so I expect it to be re-located.
    I have downloaded files from the internet to play on my Pioneer dv380, after being burnt onto Verbatim 4x DVD-Rw discs. The files I download are avi files, and are Divx or Xvid, which my Pioneer should play. However, only about 50% of the files will play. If the file will play I get MPEG4 displayed on the Pioneer, and if not, DVD is displayed and no tasks can be carried out.
    Could some patient person please help to point me in the right direction!
    Thanks, John
    Downloading is a fraight business. You cannot gaurantee the quality of the material you get, nor the consistency. Just because your player says it can play avi encoded with Xvid or Divx does mean it can play all avis encoded with Xvid/Divx. Read the manual and you will find restrictions based on Qpel and GMC and other obscure encoder settings. This may mean you have to re-encode some of these files.
    AVIRecomp is designed to re-encode using Xvid in a manner that is pretty much universally playable by certified machines. It might be worth a look. Before you do this however, can you post screen shots from g-spot of some of the troublesome files ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member SingSing's Avatar
    It takes patient. You will evenetually figured out which sites have xvid/divx files that you can play straight on your Pioneer player.
    The rest need to be re-encoded with AVIrecomp, or DVD mpeg2.
    I have a Pionner DV-470 DivX and I never had any problems with it
    But I made a firmware update from Mtz, they are not official but does a very good job
    Never converted a AVI file to DVD since then
    You can also try MPEG4Modifier to remove QPEL
    Thanks for all your help so far. I think I am in here way above my head, and you are using terms and phrases that mean nothing to me!
    Gunslinger, I am unable to post a screenshot of the file on G-spot.
    I will download the other programme suggested as see how it goes.
  1. Best DVD Player for Playing AVI files via USB (5990 vs 5960)
    By shobuddy in forum DVD & Blu-ray Players
    Last Post: 14th Feb 2009, 12:43
  2. playing files on a dvd player
    By rigger1972 in forum Newbie / General discussions
    Last Post: 16th Aug 2008, 13:23
  3. Downloaded VOB, BUP IFO files won't play in dvd player
    By COOPERMAN100 in forum Newbie / General discussions
    Last Post: 28th Aug 2007, 05:31
  4. Codec problems with downloaded avi files?
    By aelfheah in forum Video Conversion
    Last Post: 16th Jun 2007, 07:48
  5. Ripped/burned AVI DivX files not playing in pc or DVD player
    By perceptionist in forum DVD Ripping
    Last Post: 4th Jun 2007, 03:55
