Hi
I have downloaded ffmpegX because I have some .flv movies that I want to convert to .mov files to be played in Quicktime.
I follow all the specified steps and a file with .mov magically appears at the end of the process but it will not play in quicktime (or anything else). An error message appears saying "Error opening movie. The movie could not be opened."
Is this a codec issue?
Can anyone give some guidance on the correct way to do the conversion.
Thanks.
Thread: .flv to .mov using ffmpegX
May be your flv files are made by ON2 VP6.
you can search "flv to video vp6" with google.
ffmpeg/mencoder can handle VP6 just fine so as long as the builds in ffmpegX are reasonably recent then it should also handle flv's containing VP62 video.
mov to flv framerate issue with ffmpegx
By Sebbeto in forum ffmpegX general discussionReplies: 5Last Post: 23rd Mar 2010, 00:20 -
flv to avi with ffmpegx
By giovecam in forum ffmpegX general discussionReplies: 10Last Post: 6th Mar 2010, 14:52 -
Problems converting camera's MOV to FLV via ffmpegx
By ygg in forum MacReplies: 5Last Post: 13th Feb 2010, 22:27 -
What encode does FFMPEGX use for FLV?
By pieman1968 in forum ffmpegX general discussionReplies: 1Last Post: 3rd Apr 2009, 13:16 -
Divx to FLV to MOV to FLV again, just for the sake of some effects?!
By ayyash in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2008, 20:19
Statistics
Newest guides
Latest tool updates
New media comments
