I have a panasonic DMR-ES46V dvd/vcr recorder and a Proscan dvd player is there a way to view a dvd from the proscan and copy to the panasonic i have tried alot and no luck
i have both going to a hdtv with a cable box
thank you
Thread: panasonic DMR-ES46V help
Newbie needs to spend perhaps 30 seconds doing basic research.
A commercial dvd with copy protection... I kinda doubt it. A home-made dvd.... then yes. Hook up the output cables from the player to the input plugs on the recorder. Choose the proper INPUT on the recorder, then record. A better way would be to simply make a copy of the disk with your computer using a disk copy program like Nero.
Making a copy of a commercial DVD/CD is illegal unless you own the dvd/cd in the first place. If you own it then it is called 'making a backup'.
Making backups of your own home-made dvds is, like I said above, better if done with a computer instead of a dvd player then recorded to another disk. With the computer disk copy routine you loose no quality if the files will fit onto the blank media. With the play/record method you will more than likely take a hit in quality.
Good luck.
jamdj,
Firstly, welcome to VideoHelp!
You may not get many replies with the subject you have given your thread. Many users tend to pass over threads that don't describe the issue. It also makes searching harder for those with a similar issue in the future.
Make sure you are logged in, then go to your post and click the "Edit" button. You can then change your subject to something more descriptive.
Many thanks!
Cobra
thanks for the reply
sorry i am new to this site and dvd recording on a standalone unit i have one on my computer.
does the good ones have a hard drive so you can rip a dvd to the unit and record to dvd
i dont even know if this one has one
If you insist on just making a backup of the main movie, you would need a box like the Sima color corrector between the player and the recorder. The Panasonic 45/46V have circuitry to detect copy protection and stops the recorder if it detects it. The Sima or similar has a side effect of removing the signal used in preventing the backup process.
If you want a near perfect backup with menus, etc. then yes a computer backup would be better. The Guides on this site are very helpful in this regard.Panasonic DMR-ES45VS, keep those discs a burnin'
Panasonic DMR ES46V Remote Won't Work
By melvid in forum DVD & Blu-ray RecordersReplies: 12Last Post: 5th Sep 2009, 18:57 -
Panasonic ES46V Powers Off
By rgoubitz in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Apr 2008, 19:54 -
Two newb questions about the DMR ES46V
By Unikfreak in forum DVD & Blu-ray RecordersReplies: 6Last Post: 18th Oct 2007, 02:22 -
panasonic dmr-es46v doesn't work
By Delreek in forum DVD & Blu-ray RecordersReplies: 7Last Post: 28th Sep 2007, 05:25 -
Panasonic DMR-ES46V can't read blank DVD+Rs?
By DJThuht in forum Newbie / General discussionsReplies: 6Last Post: 13th May 2007, 18:20
