VideoHelp.com Forum
    I have noticed x264 in the ffmpegX ver. 0.0.9x has stop using multiple threads for encoding. The same issue also occurs when I use a custom compiled x264 build (tuned for G5) with pthread enabled.
    Is there any connection to ffmpegX?
    I'm using a late 2005 PowerMac G5 2.3 GHz dual-core with 2 GB of RAM
  2. I also noticed that x264 is using the verbose output option. The progress bar is nice and everything, but doesn't that have a significant unfavorable effect on encoding speed?
  3. You may enable terminal window output (in the ffmpegX menu of the apple bar) if to disable the Progress bar.
  1. Really odd issue playing some x264
    By NotSoEasy in forum Software Playing
    Last Post: 27th Mar 2012, 14:17
  2. Joining x264 mp4 files issue
    By dreamweaver888 in forum Editing
    Last Post: 27th Feb 2012, 18:30
  3. DXVA issue in MPC HC with x264 video
    By Phat J in forum Software Playing
    Last Post: 24th Jan 2012, 14:52
  4. x264 r1301 issue
    By leghorn in forum DVD Ripping
    Last Post: 22nd Oct 2009, 15:28
  5. i7-920 Hyper-threading
    By wulf109 in forum Computer
    Last Post: 8th Apr 2009, 20:25
