HI! I'm about to burn an MPEG-2 file that was originally an AVI that I filmed. Since I know jack-squat, and I will be looking tonight, what is the big difference between AC3 and Mpeg audio? Premire pro 1.5 can export mpeg for audio, and I have the ffmpeggui03c AC3 converter, does one sound better? It is to put on a DVD.
Thanks!
Results 1 to 9 of 9
winxp - 3.06 -
In my experience they are pretty much the same - the main exception being ac3's ability to do 5.1 audio. I think there is multichannel mpeg audio available but I'm not sure about compatibility. Basically if you want 5.1 you do ac3.
But if you are strictly stereo or mono ac3 and mpeg audio are essentially equivalent in my opinion.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Greetings,
From my research and experience, and from what I hear on these forums, go with AC3 for the following reasons:
-AC3 is a DVD standard most widely used. In fact, probably all commercial DVDs would be in AC3 if it wasn't for the royalty paid out to the Dolby Digital group.
-Some hardware doesn't even recognize the MP2 format. All of them recognize AC3.
-As you can see from the last post, AC3 gives you more options, while retaining those of MP2.
-File size isn't an issue because both are relatively the same.
-Dolby is also involved in developing AAC, a codec which is better than AC3 and should replace mp3 in the future. The point here is stick with AC3 and Dolby to ensure long term compatibility and easy conversioin to future generation systems.
-Quality? The human ear probably won't tell you, but both are lossy formats. LPCM would be the choice there, but it's so much bigger in file size and again, the human ear won't tell the difference anyway.
Go with AC3 and you should be fine.
You may need to install an AC3 codec/plug-in to play Dolby stuff on your PC. Just google it and you should find some free stuff.I hate VHS. I always did. -
what royalty? there isnt any
Originally Posted by BJ_M
As well, this will continue to apply when they release their version 4 of MPEG AAC (for MPEG 4), which would be an upgrade from MPEG-2 AAC. I'm sure it's in the news somewhere if you do a search.
Maybe "licensing" is not synonymous with "royalties", but I know there's a fee somewhere.I hate VHS. I always did. -
the only fee is in regards to the encoder - not the product ..
use of the logo is free - though you have apply for its use"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I knew there was a fee attached somewhere, not sure where it was. Then again, I could have sworn that there was some fee attached to the products themselves sporting the "Dolby standard".
Regardless, as far as this thread is concerned, I would stick with AC3 (Dolby).I hate VHS. I always did.
MPEG StreamClip - H.264 MP4 w/AC3 audio loses audio
By the_wallcrawler in forum Video ConversionReplies: 5Last Post: 25th Jan 2014, 04:05 -
Editing TiVo Recording (MPEG2/AC3) with MPEG Streamclip loses audio
By DarthEd in forum MacReplies: 15Last Post: 4th May 2012, 08:28 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
Multiplex SD Mpeg with ac3 audio
By hartless in forum DVB / IPTVReplies: 8Last Post: 9th Sep 2008, 07:59 -
How do i convert MPEG audio to ac3?
By php111 in forum AudioReplies: 9Last Post: 28th Sep 2007, 17:13
