VideoHelp.com Forum
    I have a 698 MB avi mpeg4 movie file.
    ffmpegX 0.0.9w shows the following information for this
    AVI,
    Video: mpeg4, yuv420p, 464x240
    Audio: mp3, 48000 Hz, stereo, 112 Kb/s
    Is it divx ? (which I doubt) but it is playable in divx player.
    I want to write it to cd / dvd to play it on my divx certified dvd player (Sony).
    I tried doing so by writing the file to CD through Toast 6.0 , Data tab, DVD-ROM(UDF) format, but it gave data error on my player and did not run.
    Please suggest.
  2. Explorer Case's Avatar
    DivX and similar mpeg-4 movies can be encoded with certain options that standalone players are not always compatible with (GMC, qpel). Some of those option can even be hard to detect in a movie, by lack of Mac OS X tools that provide such information.
    A DivX certified player should be able to play compatible DivX AVIs from CDs burned in ISO 9660 format. That is, UDF wouldn't be my first try...
    I would recommend letting Toast do this for you. In the video tab in Toast select DivX disc on the left and drop your video in. If the video isn't compatible, I think it'll re-encode it to a compatible format.
    Usually when you drop your video into ffmpegx the first thing that is shown on the right side is AVI DivX. Just hit encode for 2 secs and stop. Then check your encode log, the blue "i" icon and that should give you more detailed info about the video. That's how i check bitrates and such.
    Hi,
    thanks for the inputs.
    This is the information I get in ffmpegx while converting,
    AVI file format detected.
    VIDEO: [XVID] 464x240 12bpp 29.970 fps 543.2 kbps (66.3 kbyte/s)
    [V] filefmt:3 fourcc:0x44495658 size:464x240 fps:29.97 ftime:=0.0334
    Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
    AUDIO: 48000 Hz, 2 ch, s16be, 128.0 kbit/8.33% (ratio: 16000->192000)
    Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=464 h=240]
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
    Am not able to make any thing out of it.
    And I have toast 6.0, it does not have Divx DVD option.
    Any ideas,
    also, Can i get this avi converted to MPEG2 (so that i may be able to write DVD out of it)
    thanks
  5. Originally Posted by kapil.garg
    Didi you try to burn it on a cd in ISO9600 mode or Mac/PC mode with Toast, as suggested by Case ? This will certainly do the trick, unless your file uses some advanced encoding options that is not supported by your player.
    Any ideas,also, Can i get this avi converted to MPEG2 (so that i may be able to write DVD out of it)
    thanks
    For that you just have to install the DivX plug-in for Quicktime and burn your video with Toast in regular DVD-Video mode. Toast 6 is able to create a DVD/MPEG2 from any Quicktime video file.
    I'm going to assume that you've got an XviD avi. You probably should convert that to a DivX avi and then burn using the methods others have suggested.
  7. Member macsyrinx's Avatar
    If it's an XviD format, which it looks like it is, just leave it in that format, burn using the built-in Apple burn process. This process still works fine for me. I also use Toast7, Video Tab / DivX format with DivX encoding turned off. XviD's have always seemed to play better in my DivX certified player than DivX formats, go figure.
  1. Divx certified DVD player help...
    By mjl1297 in forum DVD & Blu-ray Players
    Last Post: 30th Apr 2011, 10:48
  2. Would Philips be #1 certified DivX DVD Player?
    By rocky12 in forum DVD & Blu-ray Players
    Last Post: 20th Nov 2008, 21:12
  3. transcoding for divx-certified player
    By n8gray in forum Linux
    Last Post: 20th Mar 2008, 15:34
  4. Divx Certified dvd player won't recognize 16x9 aspect ratio
    By maca in forum DVD & Blu-ray Players
    Last Post: 30th Nov 2007, 12:48
  5. Is there a difference between a Divx player and a Divx certified player?
    By Hank Kinsley in forum DVD & Blu-ray Players
    Last Post: 18th Jun 2007, 12:30
